1337 3310 tool
An hacker's swiss knife in the form factor of the best phone ever
I'm building a portable multitool in the shell of a Nokia 3310 phone. I want to integrate a lot of features, merging this multimeter: http://www.seeedstudio.com/wiki/Bluetooth_Multimeter
with this mini scope: http://www.gabotronics.com/development-boards/xmega-xprotolab.htm and some more...
The phone willl stay completely intact, I'm only redesigning the main PCB!
Features:
+ Bomb proof
+ Basic scope (+ bluetooth stream)
+ Basic signal generator
+ Servo tester
+ Mutimeter (+ bluetooth stream) (V, A, ohm)
+ Serial port monitor
+ Snake
? ESP8266
|-- web browser
|-- IRC chat
|-- web-based onterface for the devices features
L-- wifi scan
The first prototype of the device is finally completed! Here's a brief recap of what have been done and what's planned for the future.
The good:
- I implemented the feature I wanted the most, that is the multimeter with simultaneous current and voltage measurements, with instant and average power consumption graphs to estimate battery life of my projects
- My nerdiness is quite satisfied by the UI similarity with the Nokia original design
- I love the continuity function playing the Nokia Tune
- I paid a tribute to Sprite_tm with the Tetris addon
- I'm working on a better, more powerful version of the device using the Teensy, with Bluetooth 4.0 smartwatch functions.
- I wrote and published >2000 lines of code, most of the stuff can be reused
- There's now an Open Hardware Eagle library to replicate the Nokia 3310 PCB!
The bad:
- I spent WAY too much time creating tools to extract the original bitmaps and fonts from the original Nokia Firmware. My inner nerd is very satisfied, but this left me no time to add other interesting functions like the scope, the serial sniffer and the ESP8226 integration before the contest end
- Besides, I have no space left on the Trinket:
- I couldn't get the TVBgone function to work, maybe it's a conflict with the timers used in the Tone library
- The LiIon battery charger I ordered is stuck in a post office somewhere; once I get it, it's just a matter of connecting it to the header and I will be able to charge the Nokia battery from the Trinket's USB port
The ugly:
- I really need a gold plated PCB to get the original Nokia buttons to work decently
- The code to extract the fonts from the original firmware is horrible and not commented
- There's a bit of noise in the input stage. That is due mostly to the long routing of the signals, as some components like the Trinket, the button pads and the backlight LEDs can't be moved around to optimize the board
  • 1 × Nokia 3310 Mainboard not needed
  • 1 × Trinket PRO
  • 1 × PGA113 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × Custom PCB
  • 1 × A bunch of passives
  • What's next?
    Mastro Gippo01/12/2015 at 15:34 0 comments
    This project gathered a good following, so I'm now wondering where I can bring it next. There are a few things to think about and some decisions to be made. The Teensy conversion should bring very interesting improvements, that could make the product worthwhile for a crowdfunding campaign, and/or make it an interestiong open source project. But this would mean leaving the Nokia part behind, as there are not many 3310 left, the display while good is still quite low res, and there may be copyright problems.
    And by the way, I think that the Gabotronics Xminilab and Xprotolab are still the best choice for a device of that kind, even if they're missing the whole current and power measurements that first pushed me to this quest. http://www.gabotronics.com/oscilloscopes/xminilab-portable-oscilloscope.htm
    I foresee two "extreme" paths, and a whole lot of other viable paths inbetween. The best thing would be a community effort to expand and improve the Xprotolab by porting it to the Teensys Freescale micro (or better) and designing a platform with improved input handling and features; then a plethora of devices could be made, as it happened with the Gongkai ecosystem. I would build a board for the Nokia 3310, someone could build a Fluke lookalike case, or even an oscilloscope in a watch. The easy path would involve just designing boards for the original Xprotolab micro and work with its limitations, maybe with a second micro to handle UI, battery charging etc., as it's already happening with some customer-made Xprotolab devices.
    I think that the only innovation that my device brought to the table is the Nokia 3310 "integration", but in the end that's just a gimmick, a novelty. Bringing this project forward would require a great effort, and I don't know if it will be worth it. I've done 80% of the work, with 20% of the effort. Should I leave this here as a nice exercise in creativity and a fun holiday project, or should I try to bring it to the next level by working the other 80% to complete the remaining 20% of the project?
  • LCD testing with the Teensy
    Mastro Gippo01/06/2015 at 22:04 0 comments
    ...and it works! Other than more memory and more power, the Teensy also has two PGAs on board and two separated 16bit A/Ds that should help to improve significantly the original design. Well, the hardest part of the project is already done, now on to the porting!!
  • ALL HAIL THE 3310 WIZARD!
    Mastro Gippo01/03/2015 at 16:37 0 comments
  • Sources online!
    Mastro Gippo01/03/2015 at 15:02 0 comments
    I just uploaded the sources on my GitHub account! So, do you want to build it? Here's a step-by-step introduction:
    1. Get all the design files from the main repo: https://github.com/mastrogippo/1337-3310-tool
    2. Build the hardware!
    3. Download the firmware, binaries and tools from here: NokiaPack
    4. If you're lazy go to step 10, if not read on to generate the Font and Bitmap binaries yourself
    5. Use the PPM editor in the NokiaFirmware folder with the .fls file to export the .pef file with the fonts and a folder with all the bitmaps in the original firmware
    6. Get the Bitmap converter: https://github.com/mastrogippo/BitmapToBinary
    7. Place the bitmaps in the "bmp" folder with the BitmapToBinary exe, run the program, select the bitmaps to include and click "Gen"
    8. Get the PEF Fonts tool: https://github.com/mastrogippo/PEF-Fonts
    9. Place the font PEF file in the same folder as the PEF Fonts executable, run it to generate the font binaries, save them and the listed offsets
    10. Get the EEPROM upload tool: https://github.com/mastrogippo/Arduino-EEPROM-Upload
    11. Upload the sketch to the Arduino (if you have all the hardware conneted, upload the 1337 3310 sketch uncomenting the #define EEWRITE)
    12. Copy all the bin files to the EEPROM uploader folder and run it (change the serial port in the code if needed)
    13. Upload the binaries, then click any phone button to end the write process if you're using the 1337 3310 sketch; the phone will beep
    14. Comment again the #define EEWRITE and upload the sketch
    15. ???
    16. PROFIT!!
  • Video recap!
    Mastro Gippo01/02/2015 at 19:38 11 comments
    And here's a video of the latest developments!
  • 1337 c0nn3kt0r sk1llz
    Mastro Gippo12/26/2014 at 18:09 2 comments
    20141226_184246
    Well, today I started testing the analog input circuitry. As you can see, I'm soldering wires directly from resistors to the connector. The casual observer may see this as being too lazy to route a proper connector on the PCB, but it's really a very sophisticated way to relieve stress on the connector! :P
    I also had to add a bodge flyback diode to the buzzer, as I forgot to include one... That's the second error on the PCB: the other one is taking for granted that I could put two green LEDs in series. I'm too used to modern, super efficient LEDs, but since I'm reusing the original Nokia 12 years old LEDs, they need a bit more current and seem to have an higher forward voltage than the ones I use everyday.
  • PCB design
    Mastro Gippo12/26/2014 at 00:53 0 comments
    board
    Designing a replacement PCB for the 3310 mainboard requires quite a bit of effort. The first thing I did was to remove all the components from a broken phone, to get a nice scan of the board:
    3310pcb2-13310pcb2-2s
    Now I know where all the holes and pads are, and I can draw the outline of the PCB. After a lot of failed attempts and frustration with various open source softwares, I ended up using Adobe Illustrator to create an exportable vector image of the outline and holes to feed to my Roland SRM-20 mill. Here she is cutting the PCB to size:
    20141212_193338and here's the result, after a lot of tests on foam to fix minor issues:
    20141212_212104 20141212_214000it fit very well, despite the PCB being thicker than the original (1.4mm instead of 1mm).
    Time to fire up Eagle! I created a library for the phone footprint with the various pads for the LCD, buzzer, battery connector and buzzer and started laying out the board. I wanted to design a board that I could etch at home, so I had to stick with two layers, but I soon discovered that I had to give up the numeric pad to route all traces. I was still able to keep the function buttons, so I guess that I'll live with that for now!
    Etching the board was a nightmare by itself, as my printer couldn't print a design this big on wax paper without scratching a lot of the toner away; Press'n'peel is not very good either for big boards with very thin traces. After dozens of failed tests, I was able to transfer the toner well enough with the good old photographic paper technique, being extra careful with every step of the process, even going as far as measuring the temperature of the iron before heating the board.
    20141222_141156 20141222_144030 20141222_151055 20141222_161930 20141222_162025 20141222_162132TA-DAAAHHH!! Not perfect, but still very nice and usable. Since the board is sandwitched under the screen plastic frame, I couldn't have anything protruding from the PCB, so I had to transform the Trinket to be surface solderable:
    20141222_173530 20141222_173705 20141222_174844 20141222_175430Some filing and a bit of kapton to insulate the bottom pads, and I was good to go!
    20141224_173758Let's write some software!
  • Testing the PGA113
    Mastro Gippo12/19/2014 at 15:07 0 comments
    20141219_133926
    PGAs are quite common, but I don't have one in my parts bin and I was curious about an idea I had for a while...
    In the non-inverting configuration, the opamp gain is set by the two resistors ratio, and since one of them is grounded, I can add a resistor in parallel by connecting it to the MCU I/O and grounding the pin or setting it as an input to activate or deactivate it.
    I looked around the web but couldn't find anyone supporting/bashing my theory (if someone has links discussing this, please let me know), so I just tried it and it works! With the ATMEGA328P in the Trinket you must connect the resistors to analog pins, or else it will still load the amp too much when set as a digital input. Setting the pin to analog input will leave the resistor floating, and setting it as a low digital output will connect the resistor to ground. This setup is not perfect, especially at low voltages, and it seemed to further reduce the bandwidth at high gains, probably due to the input pin capacity.
    I decided to take the lazy route when designing the input stage, so to get a wide input range while keeping a good resolution I opted for a Programmable Gain Amplifier. I decided to order the Texas Instruments PGA113 as it's cheap, has 2 switchable inputs, a reference pin and a nice range of switchable gains. It comes with a choice of 8 multipliers (1, 2, 5, 10, 20, 50, 100, 200) and while the bandwidth is quite low (230kHz at the highest gain setting), it's still good enough for the Trinket ADC.
    Dividing the input by 1:100 I calculated an acceptable resolution, but to get better results I would really need a 16bit ADC and a lower gains.
    So here's the input circuitry I came up with:
    input
    it should be able to measure both current and voltage at the same time, to calculate instant power consumption.
    Time to test the PGA!
    The PGA113 comes in a VSSOP package so I just decided to build a simple breakout board with the basic passives required to make the device work. I also included two precision voltage reference sources, selectable with a jumper.
    pgasch
    20141209_231821
    20141209_234553
    20141219_134111
    The board has only one single jumper wire, so it can be printed on a single layer of a dual-layer PCB, keeping the back as a ground plane.
    Everything worked on the first try! The PGA113 is quite simple to work with, and the datasheet is clear and complete; it was just a simple matter of modifying the SPI/digitalPot example to send the right two bytes, and I had my PGA working!
    // include the SPI library:
    #include <SPI.h>
    #define PGA_CS 10
    void setup()
    pinMode (PGA_CS, OUTPUT);
    SPI.begin();
    SetPGA(0,0);
    void loop()
    void SetPGA(int G, int Ch) {
    //take the SS pin low to select the chip:
    digitalWrite(PGA_CS, LOW);
    //send in the address and value via SPI:
    SPI.transfer(0x2A);
    SPI.transfer((G<<4) + Ch);
    //take the SS pin high to de-select the chip:
    digitalWrite(PGA_CS, HIGH);
    That's it! Now on to the 3310 PCB design!
  • Nokia firmware reverse engineering
    Mastro Gippo12/04/2014 at 21:10 0 comments
    A long time ago, (I felt like) I was the coolest kid on the block, with my heavily modified Nokia 3310. A thriving community existed with the purpose of reverse engineering Nokia DCT3 phone firmwares, creating from the simplest mods like changing a few bitmaps to writing a full alternative open source firmware, aka Project MADos. Yes, I was “cooking ROMs" before it was cool.
    This is what I'm talking about:
    As the years passed, everyone got new phones and these projects got abandoned. While I was writing this article and working on my project, I looked back at the iconic websites of that era to find myself in a ghost city full of dilapidated buildings. blacksphere.tk is now just a black page. nokiafree.org attempted to renew itself providing recent Nokia news, but got abandoned early this year (but still kept the awesome forum archive). g3gg0.de, the website of one of the legendary hackers that put a lot of effort on the reverse engineering, lost a lot of the old content in an update and stopped updating his blog in 2013. Most of the links point to dead websites, and it's getting harder to find copies of the tools and firmware images. I'll upload some later.
    A 3310 phone has a very simple memory mapping:
    0×200000 – 0×340000 firmware
    0×340000 – 0x3D0000 PPM
    0x3D0000 – 0×400000 EEPROM
    and the PPM is what I'm looking for: it stores all the localization data (strings and operator list), fonts, ringtones and bimaps. PPMEdit is a nice piece of software to edit and export that data.
    On the Bitmaps window, you can find and edit all the images and export them as single .bmp files. So I just have to convert them to store the data on an external eeprom because the Trinket board that I'm using doesn't provide enough memory to store all that stuff. The PCD8544 display stores the data in this order:
    so I'll just pre-align the data in a way that will not require any further processing by the MCU, that will just have to read and forward it. I played a while to see if I could directly connect the SPI MOSI from the eeprom to the MISO of the display, to save buffering and time during transfer, but this would increase complexity a lot if I wanted to access the display from the MCU too so I'll leave this exercise for another time.
    You can find the C# code I wrote to handle this conversion in my github: https://github.com/mastrogippo/BitmapToBinary
    Preparing the fonts is a bit harder, as they are exported with a custom file format. It's not complicated at all, and I'm working on a tool to prepare that data for easy access too, but that's not quite ready yet. As the display memory is arranged in six 8bit-high rows, it's very easy to use the small fonts. Putting fonts between the rows or using the large/bold one (13px high) will require a lot of effort and CPU power, so I won't implment it now. Ladyada's library does it and eats up 35% of the flash available, and I can't afford it right now! :)
  • LCD and external storage working!
    Mastro Gippo11/28/2014 at 18:53 0 comments
    Today I got the LCD and an external FRAM working. I usually don't care much about aesthetics, but big part of this project is the Nokia 3310 styiling, so I'm taking extra care to emulate the phone as much as possible!
    I had some FRAM samples, so i opted for the FM25V10. With 1Mbit of memory, it can store 260 full screen images for the 84*48 LCD. Without huge optimizations, I can load and display an image in about 7ms.
View all 11 project logs
View all 17 instructions
Zoé wrote 11/25/2018 at 23:41 point
Do you have maybe any PCBs laying around? I'm thinking of the conf badge redesign. I would love to build this.
dave wrote 01/31/2015 at 21:46 point
I've heard that if this phone drops on your leg it's broken. The phone remains unharmed.
Jasmine Brackett wrote 01/07/2015 at 22:50 point
Congratulations on winning the Trinket Everyday Carry Contest! A brand spankin' new Rigol DS1054Z scope will be dispatched soon.
Mastro Gippo wrote 01/07/2015 at 23:23 point
Thanks Jasmine, and thanks Hackaday and SupplyFrame! :)
I hope to meet you all again soon, the Munich event was a blast! But next time... I'll go to space! :P
davedarko wrote 01/07/2015 at 23:40 point
Congratulations! Well deserved!
Stefan-Xp wrote 01/07/2015 at 23:45 point
Congratulations! Well done!
TTN wrote 01/07/2015 at 21:13 point
You should add waterproof to your list of features. My ol' nokia got washing machined 3 times before I stopped using it. The battery died xD
Mastro Gippo wrote 01/07/2015 at 23:16 point
LOL, I don't think that would be the case here! But some spray coating may do the trick... I'll have to try!
Stefan-Xp wrote 01/03/2015 at 13:10 point
Really Nice demonstration Video! I like it ;)
Good luck with the Contest!
Best regards, Stefan
Mastro Gippo wrote 01/03/2015 at 15:07 point
Thanks! :)
Adam Fabio wrote 11/30/2014 at 07:28 point
Great Project Mastro! I'm betting that with that Nokia phone shell, your tool will not only be pocketable, but bomb proof!
Mastro Gippo wrote 11/30/2014 at 10:59 point
Thanks! That was actually a feature I forgot to include, I'll add it now! :)
j0z0r pwn4tr0n wrote 11/29/2014 at 23:51 point
I know it has been done before, but if you have low-level access to the WiFi signal, you could include a visual spectrum analyzer
Well yes, it's been done a lot before, and no one did it with the ESP8266 AFAIK... But I don't think I will be the first! :)
