Rosmo robot
Modular open hardware robot for uROS2 & Microblocks
Public Chat
Modular Open Hardware robot bits.
A Open-hardware micro-robot for ROS2 that can be assembled without soldering, or access to a 3D printer.
Built using affordable components available worldwide. For hobbyists, universities, R&D. https://rosmo-robot.github.io/
Portable Network Graphics (PNG) - 250.55 kB - 05/17/2022 at 11:25
Preview
OctoCore ESP32 dev board
JPEG Image - 3.63 MB - 04/29/2022 at 09:18
Preview
JPEG Image - 3.75 MB - 04/29/2022 at 09:18
Preview
JPEG Image - 45.27 kB - 01/11/2022 at 12:30
Preview
JPEG Image - 1.23 MB - 01/11/2022 at 12:30
Preview
View all 10 files
  • 1 × BOM: https://rosmo-robot.github.io/ Passive Components / Misc. Passive Components
  • Microblocks & Mecanum working
    Samuk5 days ago 0 comments
    Made some progress, Microblocks, Mecanum are working now.
    Also got
    Theres a little video here
  • Lidar header
    Samuk04/08/2024 at 17:53 0 comments
    I added a header for the Lidar sensor I'm not sure if the new £45 one will work with ROS2 yet, but the pinout seems to be the same as the older £69 ones so I stuck one on for covenience
  • New breakout boards
    Samuk04/04/2024 at 23:15 0 comments
    I finished* routing the 'main' breakout board
    I also did one with a Wemos(ish) footprint
    Both of these are designed to connect to the Mikrobus header on https://rosmo-robot.github.io/
    * It's not actually finished, I just haven't spotted the errors yet
  • Xiao-S3 camera mount & less ground islands
    Samuk04/01/2024 at 21:53 0 comments
    I spotted a ground island in the PCB so did yet another iteration
    • Ground islands (hopefully!) removed
    • Added a bunch of capacitors to smooth out the power
    • Added a 5v header (bottom of the PCB) So you could plug in one of these USB-C connectors the idea is you could then add a USB powered Wifi/ AI camera
    • Added extra female header so you could now use the Open hardware ESP32-S3 or the closed hardware ones that are a bit cheaper
    • Bottom silkscreen tidied up a bit
    • More: rosmo-robot.github.io/
  • Onboard motor drivers
    Samuk03/14/2024 at 22:16 0 comments
    Did a bit of work on a version with on-board L9110S motor drivers, you can find that here it's currently untested, but I'll try it soon
  • Version 1.0 approaches? Stuff to do, looking for collaborators
    Samuk03/06/2024 at 09:57 0 comments
    I've just ordered a PCB that I'm hopeful will be a 'Version 1' https://rosmo-robot.github.io that I'll offer for sale on Lectronz.
    This will support Microblocks Teleop from an Android app and also ROS2 Teleop from a browser.
    There's a bunch of further software stuff that I'd like to get done 'at some point' I thought it would be good to write down some of these ideas to help potential collaborators jump into a bit of the project that's interesting to them.
    ROS2 tasks
    • Create a URDF file for simulation
    • Confirm the Lidar to be working
    • Confirm IMU working
    • Confirm Mecanum drive working
    • Configure Foxlglove studio
    • Create up to date Virtualbox image of ROS2 install
    • Use BeagleboardY-AY for on-board compute/ vision processing
    • Create Docker image of ROS2 install
    Microblocks tasks
    • Confirm Ultrasonic working
    • Confirm vl53l0x working
    • Write autonomy sketch based on distance sensors
    • Confirm OLED 'eyes' working
    • Write 'eyes' sketch to give some personality
    • Configure Android app to support voice control
    • Configure Android app to have 'eyes' so phone can be robot-mounted
    Hardware tasks
    Organisation/documentation tasks
    • Add photos to 'build' page & tweak wording
    • Add PCB to Lectronz store
    • Social media stuff, make some videos
    Arduino tasks
    • Do Arduino sketch based on Smartcar shield work
    Micropython tasks
    • Do alternate Micropython firmware
    If you'd like to get involved in any of that you could join the project team here, or chat to me on Twitter
  • MikroBUS expansion
    Samuk03/04/2024 at 14:30 0 comments
    At one end of https://rosmo-robot.github.io/ you'll spot a MikroBUS expansion header, the thinking with this is that this gives access to the ~1200 official MikroBus click boards
    There is also scope for people to make expansion boards based on the very useful pinout.
    I started having a play with one today, tackling the all important question of how to give this robot silly eyes.
    In the image below you'll see a bunch of interfaces;
    The MikroBus header compliments the on-board Qwiic and I2C breakout garden header as an attempt to navigate the I2C Zoo maybe I should stick a Grove on the breakout board to complete the menagerie..
    This variant adds a Grove & Xiao camera for on board image processing
    Read more
  • Breakout garden I2C
    Samuk03/04/2024 at 09:44 0 comments
    Did some more edits on the PCB, including adding an additional I2C breakout header, I chose the Breakout garden pin order for this header.
  • Pluggable motors
    Samuk03/02/2024 at 19:38 0 comments
    Having a bunch of encoder cabling is quite messy, It is functional but also fiddly to connect. I've almost finished a version that includes pluggable motor sockets to make the cable connection easier and less error prone
  • 1x, 2,x or 3x 18650
    Samuk02/28/2024 at 00:21 0 comments
    The robot can be configured to use 1x 2x or 3x 18650 batteries https://rosmo-robot.github.io/
View all 35 project logs
