I used the python library OpenCV to process the image that is under the arm, to allow itself to find and pickup object.
Here is the demo:
This is a simple 3 axis robotic arm with an embedded camera.
He is able to find and pick up object by itself without external control.
Hi, can you share the code at cooolbe@gmail.com? I am very thankful and grateful for your help!
