Long Range Weather Station (65€)
A cheap but precise Weather Station (Lora transmission)
Today, farm-level weather stations are becoming an effective tool for monitoring daily fluctuations in the weather. A variety of weather stations can be used according to the number of parameters to be measured, the working precision, and the range. The parameters measured by this weather station include:
rain
Air and soil temperature
Relative humidity
Soil moisture
Wind speed and direction
Solar radiation
Pressure
This weather station is cheap, accurate and easy to build.
It is versatile (we use it at our RC planes airfield!), it is precise and has a very long range of communication.
Follow this project to learn more.
This weather station was part of the Rezodo project. It has been moved to its own project as the  Rezodo project was becoming too big to be easily readable !
This weather station is intended to be easily "tunable" to your own needs :
  • transmission to the base can be done
    • directly by the station itself if Wifi is available
    • via Lora point to point to get a much greater range (currently working with more than 2.5 km between base and station)
  • sensors can be choosen among the list and two major versions do exist
    • wind only (+ sensors) for less than 50€
    • wind + rain (+sensors) for less than 65€
The design of the two main versions is basically the same but the "mechanical" parts, of course, differ. We will cover the two versions.
As key specifications we propose these two long range wireless systems, with real time operation 24/24 7/7 and energy efficient solution, "off grid" and solar panel powered.
"Wind only" weather station
As I do belong to a RC flying club, we need to know the wind conditions at the airfield. These conditions are locally changing quite fast and weather forecast is not accurate enough for our hobby !
So I decided to design a "Wind only" version of the weather station.
Here it is, installed at our airfield
The airfield is far away from electricity network and at 2.5km from the first building where we have installed the Lora receiver.
Everything is working now and we have a public access to these nice gauges!
Last minute upgrade : The weather Station is now also fully integrated into windyApp weather forecast application.
The result is a very professionnal User Interface, merging weather forecast (top of screen) with local measurements in real time. That's really cool!
And you can even change the color code :
  • green = good to fly
  • yellow = warning
  • red = too much wind you'd better don't fly
Wonder how to do this ? It's simple, follow this log : integrating your Weather Station with windyApp
Building this station is not complex. Read all this description and the logs and you will be able to build yours !
As you can see the wind sensors do work in very low wind conditions.
Price for this "Wind Only" weather Station including both emitter and receiver boards (GTW0 + GTW1) is less than 50€. Bill of Material is accessible here
Full weather station
This one is the most complete version, including all the sensors. It mainly differs from the previous one by the addition of a rain gauge.
The electronics goes inside the bottom box, wires go to the sensors into the pipes. PCB is protected against rain.
Here is a picture showing "exploded" view of the weather station:
And here it is during tests:
Weather station electronics
This schematics summarizes the electronics embedded into the weather station. The same PCB is used for the various versions of the weather station, and even for the Lora gateway 0 (the one simply equiped with Lora + wifi access + mains power supply).
In a few words, it has the following components:
  • a lora module for long range communication between Gateway 0 and Gateway 1
  • an ESP32 MCU + ESPNow (to be connected to Rezodo FDRS network if needed)
  • a rain gauge equiped with weighing sensor for accurate measurement
  • a wind direction sensor with a Hall encoder delivering 4096 angular postions (contactless... no wear)
  • a wind anemometer with hall effect sensor (contactless... no wear)
  • temperature, humidity, pressure, light sensors
More details into this log please read it as it contains important informations.
Components + mechanical parts for this schematics should cost around 65€. This price is for the "full" Lora weather station and does include the Lora GTW0 and GTW1...
To build the weather station you will have to add a few 3d printed mechanical components.
All the 3d printed parts are available on thingiverse (links on the left of the main page of this project). ...
WeatherStation_PCBV2_eagle_files.zip
eagle files (schematics and board) for Weather Station
Zip Archive - 56.98 kB - 10/06/2023 at 16:15
Download
PCBWay_weatherStation_V2.rar
Gerber files for PCB version 2
RAR Archive - 45.20 kB - 10/06/2023 at 16:10
Download
Adobe Portable Document Format - 292.45 kB - 10/04/2023 at 11:46
Preview
Download
ESP32_RFM95_full_weatherStation_dual_sided_V2_bom.xlsx
Bill of Material for the "full" weather station (GTW0 + GTW1). Total is 65€
sheet - 2.44 MB - 07/07/2023 at 09:11
Download
ESP32_RFM95_windOnly_weatherStation_dual_sided_V2_bom.xlsx
Bill of Material for WindOnly weather station (GTW0 + GTW1). Total is less than 55€
sheet - 2.01 MB - 07/06/2023 at 19:09
Download
View all 6 components
  • daylight saving time
    JP Gleyzes10/29/2023 at 09:46 0 comments
    On the night of Saturday October 28 to Sunday October 29, 2023, we gained an hour's sleep and set our clocks back an hour.
    This occured at change between 2am to 3am during the night.
    And here is how the Weather Station reacted :
    It's a success, the station woke up at 3am "summer time" and the Ntp server told GTW0 that it was still 2am (but winter time)... GTW0 updated its RTC and sent the time to the GTW1. Both slept one hour more (it was during night). And finally at 3am "winter time" both wokeup again and so on !
    Thingspeak is even showing a "lapse" of 2 hours  on the X axis, but time has changed only one hour !
    This behavior was expected but seeing it in real time was a pleasure !
  • Validation, tests and planning
    JP Gleyzes10/09/2023 at 08:17 0 comments
    This project seems simple but like all projects needs a consistant phasis of tests and validation.
    Testing approach
    I took my inspiration from the European Space Standards (I am a space ingeneer !) and taylored the ECSS-E-ST-40C  which is the "Verification Standard" for space systems !
    Stop kidding, I only kept from this standard the overall philosophy consisting in documenting and testing the specifications under realistic use cases including degraded modes of the hardware and software.
    Here are the testing cases that have been currently checked:
    • Hardware tests
      • overall test of the board
      • systematic test of each sensor
      • power management optimization (see V2 of this board)
      • degraded conditions
        • empty the battery and check of low level protection
        • energy monitoring during charge
        • cut off of charging process when battery full
      • calibration of sensors (see specific logs)
      • test of water resistance of the shell
      • test of high temperature resistance of the shell (above 50°C done ths summer)
    • communication tests
      • lora tests (frequency, spreading factor, RSSI)
      • optimization of the antenna (see biquad antenna)
      • time sysnchronization between GTW0 and GTW1
      • RTC initialization
    • integration tests and degraded conditions
      • protocol between GTW0 and GTW1
      • breaking the link and see the system recovering connection (GTW0 side and GTW1 side)
      • wifi credentials setup
      • integration with ThinkSpeak
      • integration with WindyApp
      • daylight saving time test
    • long term testing (operationnal scenario)
      • Wind only version tested for more than 3 months 24/24 7/7 . (October 9th, more than 37000 measurements stored into thingspeak)
      • Full version tested only on ground... deployment to be done
    • bad weather conditions tests
      • heavy rain : tested under several thundstorms (wind only version yet)
      • strong wind : tested under more than 60km/h wind and (with a car) at 100km/h
      • high temperature : tested above 50°C
      • cloudly days : tested during almost one week
      • ice or snow : not yet tested
    • modularity
      • sensors configuration and choice is done (wind only and full station)
      • interface with various "weather servers" done (currently thingSpeak and Windy App)
      • extensibility to Home Assistant done
      • extensibility to wider automation network done : see Rezodo project
    Nothing fancy into this log... All these tests needed a lot of time, but they were the price to be paid to get confidence into the system.
    The "wind only" weather station is now fully automatic, without any need for human intervention (initialization excepted).
    ToDo List and planning
    As said previously energy management was a critical part of the system. It has proven to work even now in october with longer nights than days!
    The "wind only" station is considered as operationnal now (october 2023)
    However I really want to test the system during winter to see if power balance is still positive. If not, I can easily decrease power consumption by decreasing measurement frequency (currently every 2 minutes). This could be done easily by a software "seasonnal" modification on GTW1 only.
    Full weather station is currently only tested "on the ground" and proved to work. I have to deploy it and test it intensively.
    Tests will focus on weighing rain gauge as the rest of the system is already qualified.
    Special care will be put on snow and ice resistance. I have to "freeze" the bucket in place when temperature is too low to avoid to block the RC servo used to empty the bucket if snow or ice is blocking it. (not a complex modification !)
    All this will be done during the 6 months to come. The goal is of course to have a system operationnal and tested during almost one year including hot summer and cold winter !
  • going further ? Usefulness of low cost IoT Weather Station
    JP Gleyzes10/06/2023 at 16:30 0 comments
    As stated into the introduction, this project started under the impulsion of farmers who needed a low cost  Weather Station remotely controled from their farm located at 2km away from their fields.
    Currently two models of the station do exist and have proven their reliability.
    But is this concept viable in the long term, is there a "market" or even a need for this low cost approach ?
    I started  a light "market analysis" for weather stations and found :
    quite a lot of solutions in the range 100 to 200$ but almost none with long range Lora transmission.
    When looking specifically for "lora weather station" the cheapest I found was the Raddy L7 Lora station, but at a price of 180 USD.
    Then come more expensive solutions like Meteo Helix (839€)
    None of them seems to have weighing bucket rain gauge and use standard tipping buckets.
    Does it mean that my very low cost station at 65€ is "the" solution ?
    Well, while searching for evidence on internet I found a very interresting paper called :
    Calibrating low-cost rain gauge sensors for their applications in IoT infrastructures to densify environmental monitoring networks
    This paper is a very recent (may 2023) preprint from gi.copernicus.org
    (Geoscientific Instrumentation, Methods and Data Systems (GI) is a not-for-profit open-access interdisciplinary electronic journal for swift publication of original articles and short communications in the area of geoscientific instruments).
    This paper is available for download and worths spending some time reading it.
    I have picked up a few sentences:
    "Environmental observations are a pillar of environmental science. They provide the necessary data to describe and model the state of the environment and its spatial and temporal changes. Furthermore, the data collected can be used to identify and assess 20 possible natural risks and thus warn of potential natural hazards. Environmental observations also form the basis for decisionmaking in environmental policy and for monitoring the outcome of the resulting measures, which requires reliable and systematically collected data."
    This seems to be perfectly in line with the "save the world" challenge#5 objectives !
     Later they do insist on the usefullness of low cost Weather Stations:
    "Developments over the last two decades in the field of the Internet of Things (IoT) allow this shortcoming of institutional measurement networks to be addressed. The availability of ever smaller, cheaper, more power-efficient devices and sensors combined with the ubiquitous availability of connectivity to the internet make it possible to collect and process data where it is needed. Even if the quality and reliability of such devices is lower than that of official measuring stations, the resulting datasets with higher spatial and temporal resolution can represent added value."
    And finally, I would like to address the requirements they propose for low cost sensors systems :
    "To improve the resolution of any official environmental measurement network, the sensor systems have to fulfil different requirements. When using a high number of sensor systems, they have to be low-cost while maintaining a certain level of data quality and reliability to ensure an effective application. Thus, sensors have to be quality checked before being used. To further reduce costs, the sensor system should be robust and low-maintenance. The proposed systems should be energy efficient so that the systems can operate for long periods of time without replacement or can be charged by solar panels. This would make the systems independent from being connected to the power grid, which maximises the possibilities for measuring sites. For real- or near real-time use of the data, the use of wireless connectivity is required to transmit the data from the sensors to the users. This also improves flexibility in the selection of measuring sites.
    The sensor system...
  • ​Integrating the Weather Station with WindyApp
    JP Gleyzes10/04/2023 at 11:45 0 comments
    Windy App is probably one of the best Application for weather forecast.
    You can find it on the web and run App on you phone as well.
    I tried this app and fell immediately in love !
    What is so different is the ability to compare models, to tune the App to your outdoor activity but also to select forecast at your specific location.
    Here is how it looks like for our airfield:
    This is the weather forecast for Deyme Airfield.
    It's great but I wanted to see if it was possibile to integrate my Weather Station into windyApp (not the forecast but the real sensors measurements).
    So I contacted WindyApp to ask them if a kind of API was existing. And the answer was YES
    integrating windyApp API into your weather Station
    Here is the documentation to integrate a local Weather Station.
    Nadia from WindyApp was extremely patient to help me to interface the Weather Station. After a few trial and errors with https on ESP32, I finally succeeded in creating the Deyme_test station on WindyApp server and to upload my very first measurement.
    Here is the sample code (the autorization token is of course obfuscated...)
      https POST and GET to windyApp using ESP32
    #include <WiFiClientSecure.h>
    const char* ssid = "YourSSID";
    const char* password = "your Password";
    const char*  server = "api.windyapp.co";  // Server URL
    WiFiClientSecure client;
    void setup()
      //Initialize serial and wait for port to open:
      Serial.begin(115200);
      delay(100);
    //wifi connection
      Serial.print("Attempting to connect to SSID: ");
      Serial.println(ssid);
      WiFi.begin(ssid, password);
      // attempt to connect to Wifi network:
      while (WiFi.status() != WL_CONNECTED) {
        Serial.print(".");
        // wait 1 second for re-trying
        delay(1000);
      Serial.print("Connected to ");
    //first connection to WindyApp server
      client.setInsecure(); // avoid to check for certificate
      Serial.println("\n*** Starting connection to server...");
      Serial.print(server);
      if (!client.connect(server, 443)) //secure connection https on port 443
        Serial.println(" connection failed!");
      else
        Serial.println(" *** Connected to server!");
        Serial.println("\n*****************************");
        Serial.println(" *** trying to POST to server!\n");
        // Make a HTTP request:
        String requestBody = "{\"station_id\":\"Deyme_test\",\"wind_speed\":2,\"metadata\":{\"station_id\":\"Deyme_test\",\"latitude\":0.1,\"longitude\":0.1,\"station_name\":\"aeromodelisme club de l\'Hers\",\"timestamp\":1687375555}}";
          POST /v10/partners/station/data HTTP/1.1
          Authorization: Bearer your token
          Host: api.windyapp.co
          Content-Type: application/json
          Content-Length: 163
          {"station_id": "test", "wind_speed": 2, "metadata": {"station_id": "test", "latitude": 0.1, "longitude": 0.1, "station_name": "testname", "timestamp": 1687375555}}
        client.println ("POST /v10/partners/station/data HTTP/1.1");
        Serial.println ("POST /v10/partners/station/data HTTP/1.1");
        client.println ("Authorization: Bearer your token provided by WindyApp");
        Serial.println ("Authorization: Bearer your token provided by WindyApp");
        client.println ("Host: api.windyapp.co");
        Serial.println ("Host: api.windyapp.co");
        client.println ("Content-Type: application/json");
        Serial.println ("Content-Type: application/json");
        client.println ("Content-Length: " + String(requestBody.length()));
        client.println ();
        Serial.println ("Content-Length: " + String(requestBody.length()));
        Serial.println ();
        client.println (requestBody);
        Serial.println (requestBody);
        client.println();
        Serial.print("\n*** Request sent, receiving response... ");
        int requestTime = millis();
        while (client.connected()) {
          String line = client.readStringUntil('\n');
          if (line == "\r") {
            Serial.println("headers received ");
            break;
        // if there are incoming bytes available
        // from the server, read them and print them:
        while (client.available()) {
          char c = client.read();
     Serial.write(c);
  • adding Wind Gusts to the weather station
    JP Gleyzes09/20/2023 at 17:00 0 comments
    A lot of our RC pilots were more interrested in "strong wind" rather than "averaged wind speed".
    So they asked for Wind Gusts values.
    I made it !
    Gusts are measured every 5s during 30s while I also measure average wind speed.
    Latest commit on my Github page contains all the source code.
    While the thingspeak channel of our Airfield weather station can now proudly show "Gusts"
    And it's the same for windyApp (here in dark blue)
  • configuring GTW0
    JP Gleyzes09/09/2023 at 09:47 0 comments
    Your GTW0 is the one which is connected to internet and which synchronizes the weather station (and other GTWs if a wider Rezodo network is in use).
    To configure the GTW0 we have to set up the Wifi credentials and the frequency of sensors measurements.
    This is done by touching the TP1 pad on the PCB and (while touching the pad) resetting the ESP32
    Then a web access point will pop up on which you can connect your smartphone
    Connect to this hotspot then enter
    1. a valid wifi ssid and password
    2. the frequency to wakeup your weather station in minutes
    that's it !
  • Wind Direction and weighing gauge calibration
    JP Gleyzes08/18/2023 at 12:27 0 comments
    Wind direction sensor
    Calibration the wind direction sensor simply consists in telling him where is the north !
    Indeed the magnet can be glued in any position on the shaft so the north pole is totally into a random position!
    To calibrate the "north" we simply align the sensor to the "north" direction, then we press the touch3 pad on the ESP32 and reset the ESP32 (remove your finger from the touchpad after releasing the reset button).
    This touch pad( named TP1) is also in the bottom right corner of the PCB
    Calibration is done by software and value is stored into the ESP32 flash memory.
    It's straightforward and simple!
     float angleValue = as5600.rawAngle() * AS5600_RAW_TO_DEGREES;
      if (touch3detected) //calibrate sensors
        Serial.println ("calibrate anemometer");
        calibAngle = angleValue;
        preferences.putFloat("calibAngle", calibAngle);
    You don't even have to physically point the sensor to the north. Just align the sensor with the axis of the PVC pipe (opposite direction of the solar panel).
    But you will have to align the solar panel to the south direction when fixing the weather station on the roof.
    So, wind direction sensor should be calibrated in this position:
    Calibration of a load cell is quite easy:
    • determine the zero offset "tare"
    • substract the zero offset from the raw value and then linerly convert this value to weight
    In my Weather station the zero offset is dynamically determined. The logic is simple :
    • once a day empty the bucket --> get the zero offset
    • if weight decreases, abnormal condition then empty the bucket  --> get the zero offset
    • if weight is too big then empty the bucket  --> get the zero offset
    The scle factor needs however a static calibration. It is done by weighing a know weight after having reseted the ESP32 while pressing the TP1 touch pad
     GetRawWeight();       //HX711 will sleep after weight acquisition
      if (touch3detected)
        Serial.print ("calibration HX711... ");
        calib = CurrentRawWeight;
        Serial.println(CurrentRawWeight);
        preferences.putLong("calib", calib);
        emptyBucket();
    The "calib" parameter is stored into the ESP32 flash. This parameter coresponds to the raw value of a know weight which is "calibWeight". Note that this value is in tenth of grams. I do use a steel ball the weight of which being 33.5g...
    Change this value to the weight of your calibration steel ball !
    //scale
    #define PIN_CLOCK  32        //output to generate clock on Hx711
    #define PIN_DOUT   34        //input Dout from Hx711
    long calibZero = 0;  //No load sensor Output
    long calib = 130968;          //sensor output - calibZero for Weight calibration --> will be auto calibrated later
    int calibWeight = 335;         //weight at which calibration is done --> expressed in gramsx10. eg 335 means 33.5g
    So the procedure to calibrate the load cell is :
    • insert your steel ball into the bucket
    • press the TP1 touchpad and hold your finger on it
    • reset the ESP32
    • release your finger
    That's it
    You should note that the same touchpad is used to calibrate both the load cell and the wind direction sensor.
    Be sure you are into the calibration conditions of these two sensors while calibrating
  • experience feedback (REX) on power management
    JP Gleyzes08/17/2023 at 14:12 0 comments
    A critical part of my project was power management.
    Here are a few words of "REX" regarding these aspects.
    The wind only weather station has now been operated on a daily basis (24/24) for more than 2 months and has performed sensor acquisition and transfer of data over Lora (2.5km range) every two minutes during day and once every 1 hour during night.
    All this being operated on a single 18650 Li-ion battery charged with a small 2W 6V solar panel.
    Here is the graph of the panel voltage captured during a few days :
    We can clearly see the repeating pattern where the panel outputs 0V during night and boosts up to 7V during full sun.
    If we zoom here is the detail:
    1. during night I automatically perform data sampling once every 1 hour to save power, at sunrize voltage is slowly climbing while at sun set it slowly decreases
    2. during a few hours the solar charger is lacking efficiciency (it's a linear charger...) and the panel falls down to 5V but charges the battery until full charge where the panel recovers and outputs full power (7V)
    3. but even during full charge when a cloud hides the sun, voltage may drop a little...
    In conclusion, the system seems to be very well "balanced" with good margin to allow operation even during winter time...
    In case of (unexpected) battery depletion I could easily change the sampling rate to 4 min instead of 2 min during winter season!  But we will see this after a few months !
    Currently the fast 2min acquisition is not a concern, even during very cloudy days the battery was charged enough to power the weather station.
  • gauges on ThingSpeak using Matlab
    JP Gleyzes07/18/2023 at 19:13 0 comments
    DIsplaying wind direction needs particular "compass gauges".
    Here is how they look on my "wind Only" Weather Station
    Among these gauges only the second one (wind Speed) is native, the first and third one need a few lines of matlab code.
    Let's start by creating a "Matlab Visualization" on your channel:
    Click on "new visualization" then select the compass one:
    Click on "create" and you will get sample code for this visualization:
    You can save and run this code to get this result:
    Although it's a good starting point, it's far from being perfect to display wind direction:
    • North south Est West are not displayed
    • arrow lines are pointing to the the direction from where the wind is coming
    • 0 is on the right side instead of pointing to north
    • angles are counter clockwise instead of classical ClockWise
    I managed to find Matlab Gurus to help me correct these defects.
    The source code is self explainatory and can be found on my github page: https://github.com/f2knpw/Long_Range_Weather_Station/tree/master/Matlab
    If you change the code by this one you will get the expected result:
    You can of course save this gauge on your channel:
    When reading the source code, you will discover that it is more a less a "hack"... There is no proper way to achieve this result... that's a pity !
  • Adding a biquad antenna to increase Lora range
    JP Gleyzes07/18/2023 at 12:01 0 comments
    To increase range of my Lora network  I decided to try a biquad antenna.
    My lora frequency being 868 MHz I used this online calculator to get the proper design: https://www.changpuak.ch/electronics/bi_quad_antenna_designer.php
    Then I built a jig tp help bending the 2mm copper wire. You can find it on Thingiverse : biquad antenna
    This being done we attached the antenna on the roof.
    Results were impressively good. Eventhough I didn't make a metal reflector for this antenna, I got a lot more power from my "Wind Only" Weather Station located 2.5 km away from the roof.
    The BiQuad antenna is a simple antenna design that offers many advantages. First is the simplicity of the design.
    The radiating element are two square with the side length equal to 1/4 midband wavelength, 83.8 mm for
    868 MHz in our case.
    Polarization of the antenna is 90 degrees from the position of orientation of the biquad, i.e. horizontal biquad (as shown on the roof) has vertical polarization.
    The metallic reflector reflects the electromagnetic waves back to the front of the antenna (-Z-axis), hence reducing the radiation to the back and improving the antenna gain and directivity in the forward direction. The obtained gain measures the ability of the antenna to concentrate radio frequency energy in a particular direction. It is typically measured in dB and found equal to 10.5 dB for the studied antenna design.
    Note that the "z axis" is perpendicular to the biquad
    Without the metal reflector my antenna behaves more or less like a dipole antenna but with better gain and directionnality.
View all 18 project logs
YY wrote 03/17/2024 at 01:15 point
Thank you for sharing!
I am curious about choosing the 18650 battery with the solar panel. I've observed some projects employing a combination of a solar panel with a supercapacitor, and batteries, allowing for seamless switching between them. Could such an approach offer a more effective solution? As you mentioned, power management plays a crucial role in this project.
truckershitch wrote 10/18/2023 at 17:14 point
Hi JP, thanks for posting your project!
I was looking at the BOM and I think some parts reflect the first version of your PCB?  I went into the Eagle files and I think these are the correct values and package sizes for these SMD components.  Can you please verify?
Capacitors
Label        Value       Package
C1           10 uF       1210
C2           0.1 uF      0603
Resistors
Label        Value       Package
R1           10k         1206
R2           12k         1206
R3           10k         1206
R4           10k         1206
R5           10k         1206
R6           4.7k        1206
R7           10k         1206
Thank you!  I also plan to port your code to MicroPython after I get things working.
rituparna.sonowal wrote 09/05/2023 at 09:48 point
2.5Km.. Cool
JP Gleyzes wrote 09/16/2023 at 08:55 point
It could be more !
Tested this lora ESP32 module up to 8km (with SF12, short message and line of sight)
aaaaaa wrote 09/04/2023 at 15:24 point
weather station is ideal for mesh network
John Lamport wrote 08/30/2023 at 19:49 point
Do you have one 18650 battery? I had a similar system, also solar charging, had the ESP32 going to sleep for 15 minutes, update date for a minute then back to sleep. I could get about 30 hours when the sun didn't come out before the battery died. How long can you get with out the charger? Thanks
JP Gleyzes wrote 08/30/2023 at 20:59 point
This is a very good question !
Have a look to this log : https://hackaday.io/project/191652-long-range-weather-station/log/222325-experience-feedback-rex-on-power-management
To summarize:
- I don't have the direct answer to your question as I didn't made this test  !
- The system has been running now for months (including very cloudy days) without issue
- the trick is : shut down every electronics while sleeping (done with a devoted voltage regulator with a "enable" pin)
- adapt wake up cycle between days and night. I do compute sunrise and sunset. Daytime cycle is every 2 minutes. Night cycle is every hour
- cross fingers that it still works during winter! If not I can delay day time cycle (every 2 minutes is probably too often for my use case ?) Or increase battery size ?
Meanwhile have a look to the panel voltage on this link : https://thingspeak.com/channels/2209680 (field 2 chart)
and yes it's a single 18650
JP Gleyzes wrote 08/11/2023 at 05:56 point
2.5km was got with the 6.5cm wire antenna and with SF7.
But to secure transmission I am now with a biquad antenna for "reception" and a spreading factor of 12.
With this I can send and receive even behind trees at more than 2.5km.
I tested it in line of sight at more than 8 km. lora is quite impressive !
Elbert wrote 08/10/2023 at 21:45 point
2.5 km is impressive. I was wondering which spreading factor (SF7
till SF12) you are using and if you could even get a longer range by
using a higher SF value (with lower bit rate however).
JP Gleyzes wrote 09/20/2023 at 18:55 point
Yes SF12 gives highest range. I tested this device up to 8km in line of sight but with a dipole antenna I built a few years ago :  https://www.thingiverse.com/thing:2789234
For the weather station I added a Biquad antenna (without ground plane) on the "receiver" side : https://www.thingiverse.com/thing:6128519
But a simple piece of wire on the station side!
