Are you tired of searching for the best way to clean Cricut mat? Then don’t worry at all because I have got your back. If you are a crafter, you will agree that the Cricut cutting mat is crucial in creating something new. Crafters use this crafting supply to stick their materials together when making DIY projects. They also come in 4 different ranges and colors.
The mat starts losing its stickiness at a certain point due to an excess amount of dirt, debris, and leftovers. To extend its life, users should know how to clean them. No doubt, cleaning mats can be a little of a tedious task, and doing it by yourself will save you money. Besides, you will also learn new things you weren’t aware of, and that can help you create unique crafts.
This blog will teach you about different methods that will instantly bring back the shine to your Cricut cutting mat.
Method 1: Light-Duty Cleaning
If you are making simple projects out of scrapbook paper, vellum, or sticker paper, then referring to these methods will be your best choice. You can use them after finishing every project to ensure that the mat doesn’t lose its stickiness. Take a look at the below section, and you might find the best way to clean Cricut mat:
Scraper Tool
You can use this tool to remove the leftover pieces of materials after the cutting process is complete. To properly clean the mat, you need to pull its edges over its surface, and it will instantly scrub away the unwanted materials from the mat. Apart from removing the material, many DIYers use this crafting item to stick the material correctly on the surface of the mat.
Lint Roller
Apart from the scraper tool, the DIYer can also use a lint roller as one of the hacks to clean the Cricut cutting mat. Just grab the roller handle and start rolling over the mat, covering the entire area. Most crafters prefer the lint roller to remove small materials such as hairs, fuzz, etc.
Baby Wipes
Besides a scraper tool or a lint roller, the crafter can use baby wipes to clean the mat. It is the best way to clean Cricut mat as it is simple and complete within a few minutes. First, you need to take a piece of wipe in your hands and gently move your hands, covering the entire area of the mat. After doing that, repeat the same step, ensuring you don’t put too much pressure on the mat.
Method 2: Medium-Duty Cleaning
If you make any customized project using medium-weight material like heavy cardstock, adhesive vinyl, or HTV, then you need to clean the mat using dish soap and a sponge. Go through the below steps and learn how to dislodge the remaining pieces of medium-weight materials from the Cricut mat:
- Start the process by putting the mat on a flat surface and letting the clean water pass through the mat.
- Once the mat gets wet, drop some dish soap on the sponge and squish until it makes foam.
- After that, slowly scrub the mat surface clockwise and anti-clockwise at least once.
- Lastly, place the wet mat in the clean area and let the mat dry naturally.
Method 3: Heavy-Duty Cleaning
In case you are making any craft out of leather, wood, or other fabric, then there is only one way for you to clean the mat, i.e., awesome spray. It will surely be the best way to clean Cricut mat. To make you look new again out of this item, then have a look at the below steps:
- First, you need to put your mat on a flat platform and cover the mat equally with spray all over it.
- Keep the mat aside for 10-15 minutes, and don’t touch it during that tenure.
- When the mat will soak the entire spray, take a sponge or a scraper tool and start removing the material.
- Finally, place the mat under the lukewarm water and hang it vertically to dry with natural heat.
As a result of the best way to clean Cricut mat, you have all the methods that will make your Cricut cutting mat look new again.
Frequently Asked Questions
Question: How Can I Extend My Cricut Mat Life?
Answer: To extend your Cricut cutting mat’s lifespan, clean the mat regularly. Besides, you should use the correct method while cleaning it, such as a scraper tool, lint roller, and baby wipes. Keep the mat inside the plastic sheet after cleaning it and protecting it against dirt or debris. You can also increase the mat life by using it with compatible cutting machines & materials.
Question: How to Clean Cricut Fabricgrip Mat?
Answer: Most crafters choose the Fabricgrip cutting mat when making any project out of any fabric, such as leather or cotton. This Cricut mat is a little delicate, so softly removing the material is essential. To remove the material, gently use tweezers, lift the small pieces, and sleep them at the corner of the table.
Question: How to Make Cricut Mat Sticky Again?
Answer: Read the following steps to make your mat sticky again:
- You must start cleaning your Cricut mat with a scraper tool or baby wipes.
- Next, cover the mat edges with masking tape so the adhesive doesn’t flow out corners.
- After that, spread the adhesive and cover the entire mat equally.
- Let the adhesive dry for at least 10-15 minutes, and you will get your mat sticky again.
Visit: cricut.com/setup www.cricut.com/setup login cricut design space app cricut explore air 2 download design.cricut.com/setup install cricut design space app
