As you know, Cricut machines are amazing. You can use them to create thousands of creative stuff like tote bags, keychains, cards, stickers, decals, etc. If I tell you about my crafting journey, it's too long. I started when I was a teenager just for a hobby, but I didn't realize when it would become my business. Well, if I share my story, this blog isn't enough. So, let's discuss the matter we are here for. I know you want a little clarity on how to connect Cricut to iPad. Don't worry; I'll share everything with you to make your work easier.
My blog is dedicated to iPad users who are struggling with their Cricut machines and want to learn how to connect them to an iPad. Let me walk you through this guide and teach you the process.
Introduction to Cricut Design Space
Before we move forward to learn how to connect Cricut to iPad, let's learn about its special software and its excellent features. This application or software is designed for Cricut users to create creative designs. Also, you get multiple features in this software, including different fonts, texts, templates, and designs; you'll be able to design anything you want. To get this software or application, you need to install it from Cricut's official website.
How to Download Cricut Design Space on iPad?
If you want to download and install the Cricut Design app on your iPad device, follow the steps below.
- In the first step, go to your App Store on your iPad on the home screen.
- Now, look for the Cricut app that looks like a green C letter inside a white square.
- After that, click on the Get button to get the application and verify your download with iTunes password.
- When you download the app, launch it and choose either the Sign In or Machine Setup option.
- Now, you are ready to connect your machine.
That's it for the Cricut Design Space download on an iPad. Now, let's check its connection process.
How to Connect Cricut to iPad via Bluetooth and USB?
Here comes the final step, which is to connect your Cricut to an iPad. To do this, you'll need to use the Bluetooth pairing option. Go through the steps below to learn the connection process.
Method 1: Using a USB Cable
If you want to connect your Cricut to a wired connection like USB, you need to follow the steps below. A wired connection is helpful in many ways and can be set up hassle-free.
- When you buy a Cricut machine, you receive a USB cable inside its box.
- Take that USB cable to start a connection.
- Now, connect one side of your USB cable to the iPad's port and the other side to your Cricut machine.
- After that, verify whether your machine is ON or not. If not, power it on.
- Next, head to the Cricut Design Space software and tap on the Cricut New Product setup option.
That's how to connect Cricut to iPad with USB. After this, you can utilize your Cricut to create anything.
Method 2: With Bluetooth
Check the steps below to learn Cricut setup on iPad via Bluetooth. This wireless connection is amazing and will work best for you.
- In the first step, ensure that the distance between your devices doesn't exceed 10-15 feet.
- Now, check whether your Cricut machine has Bluetooth connectivity or not. If not, purchase a Bluetooth adapter.
- But if your machine has built-in Bluetooth, that's good, too.
- Next, turn on the Bluetooth on your iPad too.
- Now, your iPad will scan for the nearby Bluetooth device.
- Then, you can select your Cricut model from the list.
- Once you choose your Cricut, you'll get a request to enter a PIN code.
- Type "0000" into the PIN box and choose the Pair option.
- Finally, your Cricut is paired with the iPad smartphone using Bluetooth.
That's how to connect Cricut to iPad via Bluetooth. If you want, you can go for a wired connection such as USB.
FAQs
Why Does My iPad Need to Download the Cricut App?
There are certain minimum system requirements you need to check before you download the Cricut app on your iPad. For instance, your iPad version should be 11 or the latest. Also, your internet connection should be strong and within 2-3 Mbps to download and upload. If everything meets, you can connect Cricut to iPad.
How Do I Connect Cricut to My Computer?
To connect your Cricut machine to a computer, follow these steps:
- In the first step, connect your Cricut to the power supply and enable it.
- Then, set up your Cricut machine with a USB or Bluetooth connection.
- Now, go to the design.cricut.com /setup on your internet browser to get the app.
- Next, download and install the Cricut Design app.
- Moving forward, proceed with the on-screen directions.
- Also, sign in to your Cricut account.
- If you're a new user, you can create a new Cricut account as well.
What to Do When My Cricut Is Not Connecting to My iPad?
When your Cricut is not connecting to your iPad it can happen when your Cricut or iPad device is not connected to the power supply. If you're using a USB cable, your cable may be loose, and if you're using a Bluetooth connection, maybe your device's Bluetooth option is not ON.
Visit: www.cricut.com/setup login install cricut design space app
