Diabetes mellitus is a global problem, in 2013, 382 million people have diabetes worldwide, most with more than 45 years, and global economic cost in 2014 was estimated to be $612 billion USD. The future projections are not encouraging.
All forms of diabetes increase the risk of long-term complications (cardiovascular disease, blindness, chronic kidney desease, etc.), however, the complications of diabetes are far less common and less severe in people who have well-managed blood sugar levels.
Today, the diary glucose level check can be done at home, nervertheless, its need a little drop of blood and a chemical reaction strip. So, this check becomes painful and expensive (each strip could cost 0.33 USD). These drawbacks decrease the patient adhesion to treatment.
I propose a glucose meter design based on light absorbance of glucose that already been extensively studied and sucessful applied in laboratory scale.
![](https://cdn.hackaday.io/images/2949751426086970074.jpg)
However, until now, the comercial (FDA approved) glucose meters still using blood samples or cost hundred, thousands of dollars.
Two challenges are found in construction of this type of device: calibration data and ultra-low-noise absorbance measurements. Raw data is not a problem to me, as a diabetic type 1, I have more than 4 measurements per day, which I can trust and use.
The big challenge is therefore how to build a precise sensor but keeping it small and cheap. I think that using very large integration time and simple InGaAs PIN diode we will be able to reach the necessary precision.
Complementary wavelenghts (850 and 940nm) are a good source of information about water and blood quantity.
Since traditional capacitive transimpedance amplifier suffer from saturation and integration time problems, another ADC aproach will be used. With a current controlled oscillator (CCO) and a digital counter, the integration time will be limited only by digital counter output register, and we will far from expensive high resoluton ADCs.
The general design is presented below:
Initially, the couple tlv3201 (comparator) and sn74lv8154 (counter) was chosen to provide a 32bit counter for less than 1$.
I did not find one good CCO IC yet. So, I will try to make my very own oscillator
The op-amp (AD8616) and transistors(ALD1106 and 1107) will cost less than 2$ each one. And the funcionallity was confirmed by SPICE simulations.
It's time to make PCBs!!!!
Nice! Following your project!
