What is the Half-flow Hold Function of the Driver?
mark-liuMark Liu wrote 10/06/2023 at 01:50 • 3 min read • Like
1, what is the stepper driver half-current hold function?
Half-current drive is a commonly used control method in stepper motor control. The realization of half-current drive requires the stepper driver to have the ability to select half-current drive. Once the half-current drive mode is turned on, the drive current of the stepper motor will be reduced to half of the set current value, and even if there is no movement of the motor, the driver will still provide enough current to keep the motor in position. This can reduce the heat loss of the motor, reduce noise, and improve the accuracy and stability of the motor.
However, under some working conditions, stepper motors need to work in full-current drive mode, otherwise it will affect the efficiency and accuracy. At this time, it is necessary to have a stepper driver with automatic switching half-current/full-current mode. Stepper driver automatic half-current function to realize the principle is mainly through the detection of the current size of the stepper motor, if the current of the stepper motor is less than the set half-current current value, it will be automatically switched to the half-current mode, otherwise, keep the work in the full-current mode.
2、What is the role of half-current hold function?
     The half-current hold function has several functions. First, it can prevent the stepper motor from losing position when it stops rotating. Second, it can reduce the power consumption and heat generation of the motor in the stationary state. Finally, it can improve the response speed of the system because the motor does not need to wait for the current to re-establish when it needs to restart.
3、How to enable the half-current hold function of the drive?
     Enabling the drive's half-current hold function usually requires corresponding adjustments in the drive's settings or configurations, and among the many dial codes of the drive, SW4 plays just such a role. As shown in the figure, when the dial code is in the "off" state, the half-current hold function is open; when the dial code is in the "on" state, the half-current hold function is closed.
4、What is the effect of half-current hold function on stepper motor?
      The half-current hold function can provide a certain holding force, so that the stepper motor can hold its position when it stops rotating. However, since only half of the current is provided, the half-current hold function may reduce the maximum torque of the stepper motor. Therefore, it is necessary to weigh the torque and position holding requirements when choosing to use the half-current holding function.
5. Advantages of half-current hold function for stepper drivers
a. Improve motor accuracy and stability, reduce motor heat loss and noise.
b. Automatically switch half-current/full-current mode to realize intelligent motor control and improve system stability and efficiency.
c. Strong adaptability, able to automatically adjust the motor drive mode according to different working conditions, improve the power density and control accuracy of the motor.
d. High degree of system integration, can be directly connected with a variety of stepper motor controllers and program controllers to achieve intelligent control.
6、Application of half-current holding function of stepper driver
The automatic half-current function of stepper driver is widely used in all kinds of stepper motor control system, which can improve the control accuracy and stability of the motor and reduce the heat loss and noise of the motor.
In some high-precision control systems, the automatic half-current function of the stepper driver is especially important to better control the precision and stability of the motor, and at the same time, reduce the wear and tear of the motor in the process of work and improve the life of the motor. The half-current hold function is suitable for applications that require the stepper motor to hold position when it stops rotating, such as precision positioning systems, automation equipment and robots. It provides better position control and system stability.
The stepper driver auto half-current function is an automated control technique that is extremely beneficial to stepper motor control and offers great advantages in motor control and optimization. Mastering the principle, application and advantages of the stepper driver auto half-current function can better realize the intelligent control of the motor and improve the precision and stability of the motor.
Like
