Second batch of the board on the road
04/19/2016 at 05:12 • 0 commentsWe've fixed some issue from the first batch and adding some new features:
1. adding ceramic antenna in order to reinforce the signal when external antenna is off.
2. fixed outside shape to have better identity and user friendly when adding breakout board.
3. adjust the screw hole so that the screw wont affect the nearby electronic.
4. fixed the silk print layout.
the new board seems awesome! just sent out to the manufacturer. Really cant wait to get the board on hand. XD
Motor Driver v0.1 Hardware Schematic
04/16/2016 at 02:45 • 0 commentssupport four DC Motor,
also support the stepper Motor Driver;
Then, support four servo.
Input voltage range: 5 ~ 12 v -
HICAT.Livera V0.1 Hardware Schematic
03/29/2016 at 15:57 • 0 commentsSchematic of must basic components as below:
Bridge between HI3518's UART1 port and 32U4's UART0 port, which enables serial communication beside both chips.
