So what will be next steps for MeshPoint?
We need to reduce size of solar mppt charger/battery management PCB and integrate it into MeshPoint case with batteries.
But we are also looking into what are other use cases for MeshPoint so we partnered with Hexaworx drone engineering company to create drone for crisis situations.
Here is MeshPoint Hexaworx drone maiden flight and few photos.
We managed to establish wifi link 1km away without problems on first try. In out next test we will do 5km and 10km range tests.
![Deploying MeshPoint Hexaworx drone Deploying MeshPoint Hexaworx drone](https://cdn.hackaday.io/images/4036051508593771545.jpg)
![Final per flight checks Final per flight checks](https://cdn.hackaday.io/images/6348201508593790942.jpg)
![Final per flight checks Final per flight checks](https://cdn.hackaday.io/images/627631508593805027.jpg)
![Our open source mppt solar and battery charge controller Our open source mppt solar and battery charge controller](https://cdn.hackaday.io/images/5890651508593821062.jpg)
![Fly little birdie, fly... Fly little birdie, fly...](https://cdn.hackaday.io/images/5510821508593955084.jpg)
Is that drone tethered to your power source on the ground? Interesting...
