Many amateur radio operators use Anderson powerpole for DC power distribution however in the UK there isn't much choice in power distribution for this connector. this project aims to create a high current DC distribution system without the cost of existing solutions.
All of the components as well as the PCB's and case acrylic have now arrived. meaning the board can now be assembled. Wasn't a hard board to assemble but does need a soldering iron with a large tip so that there is enough thermal mass to make the joint before heating up to much of the board.
The first test cut of the housing was successful, will add some laser engraving to the final version to mark maximum ratings and other important information. Ill put the cutter and cad files up when I have done this for anyone who wants to make one.
The initial designs have been completed and the electronics parts and PCB's have been ordered. The PCB can be seen below, not a complicated affair just lots of copper pours to take the current. Now need to wait for the boards to be made and for everything to arrive.
Inspired by this project, I made my own design, using the right-angle version of the PowerPole connectors and an aluminum case. More info here: https://github.com/zeroping/PowerPoleDist
I really like how the case came out, and getting aluminum laser-cut wasn't much more expensive than getting acrylic laser-cut, although it did take some CAD work.
Anyways, thanks for the inspiration!
