Wireless rocket motor test , software pc delphi borland 7 , software pic , mplabx compiler xc8 ,
x-msdownload - 873.50 kB - 03/27/2016 at 15:43
Where is the jumper ?? , this is in the datasheets from hx711??
Hi , thanks , your projets looks very goods too , about x711 , yes 10 hz from the hx711 , is work very good , the apc230 is great too
Were you not able to get it to 80Hz? My hx711 I had to change a solder bridge to makes 80Hz from default 10Hz
Looks very good! Are you only getting the 10Hz from the hx711?
Frank Herrmann
Dominic Robillard
Thomas
Xander
Yes, delete it Cancel
You are about to report the project "Wireless Rocket Motor Test ", please tell us the reason.
