Efficiency of Buck Converter
A project log for Arduino MPPT Solar Charge Controller
The charge controller consists of a buck converter that is controlled by an Arduino via a half-bridge driver.
tobiasTobias 04/01/2016 at 01:080 Comments
A test of the efficiency of the circuit with an input voltage of 10.5 Volts and a load resistor of 10 Ohms shows that in the high duty-cycle region of the PWM signal, the efficiency is over 90%.
