This project aims to get working setup of e980 LCD(LH550WF1-SD01 panel from LG) with ssd2828 Parallel LCD->MIPI bridge. Also I want to get working linux drivers for Beaglebone board as example.
Adopted sample code from datasheet to stm32f3 deiscovery board, was able to read ID of the IC. Connectors arrived, schematic for adapter board almost ready!)
Right now I've received LCD and looking for PCB connector. Still waiting for ssd2828 breakout. Next step will be manufacturing board to connect LCD to ssd2828 + backlight driver
I'm assuming this is dead in the water?
