I wish I could say otherwise, but this project looks like a failure, at least for high accuracy positioning. It's works great for torque multiplication and appears to have pretty good precision, but a 3D printer Z axis needs both precision and accuracy.
There's a problem visible in the video below: when the Z axis is moved in 1 mm intervals, every other step is right on and those in between are a little off.
UMMD 40:1 worm drive precision testing and belt stretch under load from Mark Rehorst on Vimeo.
I managed to repair the extruder and ran a test print yesterday and got Z ribbing every 2 mm, most likely because of a problem with the worm gear which spins 1 revolution for every 2 mm of Z axis movement.
![](https://4.bp.blogspot.com/-_WnQ6nhaZ60/WsmkTYmsJ4I/AAAAAAAAVT4/lJ-1Y7xupYAy1mQkcWOniAC0kroV-nFkwCLcBGAs/s1600/04080001.jpg)
I don't think there's anything that can be done to fix this. I'll be putting the Rino back into the machine today.
