FDM printing second attempt
A project log for Refreshable Braille Display
A cost effective way to make a refreshable braille display
vijayVijay 04/13/2016 at 19:340 Comments
Removed the cams from the pin-lever arrangement, and printed
it flat on the build surface, instead of an angle as attempted earlier. Better results, the pins can independently move.
I reckon modifying the printer to use a 0.2mm nozzle instead of a 0.4mm nozzle will yield better results.
