Never Stop Playing With Blocks!
A project log for Mouse Controller Project
USB trackball mouse controller inspired by Caleb's thecontrollerproject.com.
frankstripodfrankstripod 06/10/2014 at 09:341 Comment
Never stop playing with blocks; you may lose your imagination, ingenuity, creativity, and grow up and die!
One last dry run to fine tune the shape (its like OCD Legos for nerds!) I did a final adjustment to the shape of the ball and cup assembly. I also moved the ball up more to allow for more lower thumb buttons (hand picture). The final assembly will fill in behind the cup, lower side walls and bottom plate.
Hari Wiguna wrote 06/11/2014 at 01:42 point
Is it sturdy enough as it is or will you have to eventually use glue to make it more permanent? Either way, it's looking pretty awesome!
