Degradation of Rhodamine B using Acetic Acid
A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
david-h-haffner-srDavid H Haffner Sr 10/07/2016 at 12:330 Comments
This procedure is unique in the sense that it is called "spiking the sample," an initial baseline scan is run and without interruption of laser excitation, the sample is "spiked" with the Acetic acid at timed intervals like a camera taking multiple snapshots.
