Bed Support Plate
A project log for The Print3r
All Metal Triple Extruder Water Cooled Delta 3D Printer
oneohmoneohm 10/10/2016 at 00:560 Comments
In order to route the power and thermistor wires to the control board I used an high speed cut-off saw to chop out a hole in the center of the stainless bed support plate.
This turned out to be pretty difficult as this stainless plate is 3mm thick. The heat caused it to warp slightly, but I was able to (with the careful application of force) flatten it out again.
Closeup (the bottom is not this nice looking):
