Pictures below show assembled PCBs. All components can be soldered using only soldering iron with fine tip. Since my PCBs were milled I had to manually connect vias. Best thing to use is solid core hookup wire. Also there were some traces damaged during milling so they needed to be repaired. All in all it took me 30 minutes to assemble the complete module.
To ease assembly process I like to mark components I already placed.
![](https://cdn.hackaday.io/images/2218381527965505913.jpg)
