The PaperBack supports ED060SC4 / LB060S01 / LB060S04 displays. I happen to have an ED060SC7. In this project I hope to fork the PaperBack breakout board and adapt it to my own display. I'm planning to use it with a Tinker Board.
OK folks, sorry... it's proven to be too difficult for me. I'm posting this draft from half a year ago now, it holds a little more information. I finally chose for a display from a TI-83+ graphing calculator, which was easier. I might do a writeup on that.
In the "Files" section I uploaded datasheets of the SC4 and the SC7 displays. Comparing:
Features & active display size 100% similar
Slightly different outer dimensions
Pin namings:
CL, LE, OE
XCL, XLE, XOE
SHR
GVDD, GVEE
VGG, VEE
GMODE1
MODE1
U1SPV
XSPV
SPH
XSTL
VBORDER
BORDER
Furthermore the SC4 seems to have two sets of gate drivers. The SC7 seems to don't have this (upgraded version?). The PaperBack schematic just connects the gate driver pins for the two sets all together, and pulls SHR high all the time.
Voltages are 22, -20, -15 and +15 V for both panels. Maximum power of the SC7 is 1131 mW vs 1100 mW on the SC4 :-D Clock is still 200 kHz.
Conclusion: it all looks very similar. Yay!
Power-on sequence looks different to the eye, need to look into that further. But it might just be a matter of styling the PDF...
