This microcontroller-based system simplifies control electronics for optical fiber-based fluorescence measurements in neuroscience.
x-zip-compressed - 3.81 kB - 04/26/2019 at 20:13
x-zip-compressed - 3.72 MB - 08/21/2018 at 20:55
octet-stream - 43.00 kB - 08/21/2018 at 20:54
Standard Tesselated Geometry - 52.04 kB - 08/12/2018 at 22:02
Standard Tesselated Geometry - 1.07 MB - 08/12/2018 at 22:02
View all 7 files
View all 19 components
Download following files and store on your computer:
1) PhotBox_v1d_sch1_2018-07-24.zip
2) FibPhotBox_v3_lid.stl
3) FibPhotBox_v3_box.stl
4) fibPhotBox6_LPC1768.bin
Navigate to:
https://www.seeedstudio.com/fusion_pcb.htmlClick "Add Gerber Files"
Navigate to and select "PhotBox_v1d_sch1_2018-07-24.zip"Click "OK"
Make sure PCB Dimensions are 100mm x 160mm
Select desired color
All other default options should be OK
Order all other commercially available components off of parts list from Digikey,
McMaster-Carr and National Instruments
View all 13 instructions
Salvador Flores
octaviogress
Dan Sheadel
Stefan Wagner
Yes, delete it Cancel
You are about to report the project "PhotometryBox", please tell us the reason.
