This breakout board converts a 44 pin PLCC package version of 8051 or 8052 into a 40 pin wide DIP package. The breakout board also includes a 11.0592MHz crystal for proper baud rate generation, as well as 4 bypass capacitors.
Eagle CAD Design Files - This work is licensed under a Creative Commons Attribution-NonCommercial 4.0 International License. CC-BY-NC 4.0, Copyright (C) 2019, David Anders. All Rights Reserved.
PDF Schematic For TO252 LDO Board - This work is licensed under a Creative Commons Attribution-NonCommercial 4.0 International License. CC-BY-NC 4.0, Copyright (C) 2019, David Anders. All Rights Reserved.
Adobe Portable Document Format -
16.66 kB -
05/10/2019 at 23:02
i have a base board in the works with breakouts for RAM and ROM as well. i have a large quantity of these 8052 chips (a little over 16k pieces), so i plan to make these board available via tindie. 8052 board will probably sell for something like $3.95, certainly not hundreds! hehe
Does this break the PLCC pins out into the original 40-pin wide DIP pinout? If so, we've come full circle...
