Remote Telescope Appliance
Control and operation for remote telescope's support devices
This unit integrates several support hardware items for operation of a remotely operated telescope.
The functions the device performs are:
1) supplies filtered DC power for the telescope mount
2) controls two unipolar, 5 wire steppers motors
3) provides a charger output for a DSLR camera battery
4) supplies +5Vdc for powered USB hub
5) accepts two, I2C LM75 temperature sensors
6) accepts one, DHT22 single wire humidity temperature sensor
7) provides proportionally controlled 15V Dew heater outputs based on humidity and temperature
8) supplies two +15Vdc/30W outputs for camera thermoelectric coolers
Control of the various functions is managed using and Arduino Mega and Nano.   Control of each function is split between the Mega and Nano.
NanoAssySchematic-ScopeV5 01-15-19 pg7-7.pdf
Page 7 of the entire project. The Arduino Nano circuit card assembly. Since this portion will of the project will exclusively communicate with an ASCOM driver, it has its own dedicated USB interface. The Arduino Mega has its own USB interface. The hardware component count is kept low, with the help of code. The Arduino stepper library is used to energize the appropriately coils. N channel FETs with logic level Vgs thresholds are used to individually energize the stepper coils, keeping the part count and stepper driver cost low. In the code, to reduce coil heating when not moving, the digital outputs drive each gate low sending each FET to an open drain state. When a movement command is received, the gates are returned to their previous state before using the stepper library.
Adobe Portable Document Format - 30.84 kB - 01/25/2019 at 13:14
Preview
Download
Scope_setup_diagram.pdf
Functional block diagram
Adobe Portable Document Format - 26.55 kB - 01/18/2019 at 00:39
Preview
Download
  • 1 × Arduino MEGA 2560 REV3
  • 1 × Arduino Nano V3.0 ATmega328P
  • 1 × MOSFET P-CH 60V 12A IPAK ON Semiconductor NTD2955-1G
  • 14 × MOSFET N-CH 60V 11A I-PAK ON Semiconductor RFD3055LE
  • 7 × IC CURRENT MONITOR SOT23-5 Microchip Technology HV7801K1-G
View all 9 components
  • Build done, Initial checkout
    Paul Hitchcock01/25/2019 at 12:26 0 comments
    Units done and performing initial checkouts.  Since most functions need an Arduino to function, there is a parallel effort to write and debug code.
    The Nano which supports that will support ASCOM control is functional.  The ASCOM driver has yet to be written.
View project log
bball42 wrote 1 天前 point
Many modern appliances are equipped with safety features designed to protect users from accidents or hazards Salicru EQX2 33004-T [22/138] Instalación del dispositivo de monitorización. For example, washing machines have automatic shut-off mechanisms in case of malfunction, while induction cooktops only generate heat when compatible cookware is placed on them, reducing the risk of burns.
roberto wrote 06/09/2023 at 21:56 point
Hello friends. I have a project created with relays, voltage sensors, and an Arduino Nano. In this project, I use the sensors to monitor the voltage range, and if it goes out of range, the relay disconnects.
I would like to integrate it into your system, but instead of using relays, it would be better to use MOSFETs because they are smaller in size.
Paul Hitchcock wrote 01/18/2019 at 02:04 point
Oh it is a lot.  and a lot of documentation.
This is my third one, the first and second units had limited expansion and functionality.  This one incorporates the functions from the previous two.  I wanted to ensure this one had a little extra growth.
Dan Maloney wrote 01/14/2019 at 19:30 point
That's quite a collection of connectors! Hope we get to see what they all go to -- looks wonderfully complicated.
