Three Axis Helmholtz Coil
Three Axis Helmholtz Coil.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Design and construction of the Earth's magnetic field simulator Three Axis Helmholtz Coil.
This device is used to simulate the magnetic field of the earth. It is also used to calibrate a variety of passive and active magnetic sensors. One of the applications of this system is to provide a navigation guidance algorithm based on the magnetic field of the earth.
