i found the short circuit, i mixed up a 0Ohm Resistor with a Capacitor.
![](https://cdn.hackaday.io/images/9961561601817004560.jpg)
After removing this capacitor it was possible to program the Watch. Sadly i noticed, that the BMA is not working....
Seems like i might have killed it by soldering it to hot and/or to long.
So the next Todo is to build a Soldering rig, where i can solder these little chips reproducible.
