It's a shitty Add-on Library! for Eagle! Everyone gone done kicad, nobody done do eagle cad, so I done did it for y'all. this has both the badge and the add-on format. be sure to flip the SAO one to the rear of the card so it's set up right for manufacture Once/if I figure out how this works, I'll do the same in the template. if you use it, drop me a line. thanks!
Downloaded the library but it looks like its the defcon 26 2x2 connector
