Update
While I have been waiting for the end-mills, drill bits, 6mm acrylic sheets and acrylic glue to arrive, I have been working on other projects. The orders have arrived and I have finished the other projects.
Where was I?
Here is may last plan for 6 mm thick acrylic:
![](https://cdn.hackaday.io/images/7245441559871928698.png)
My last Section:
![](https://cdn.hackaday.io/images/616951559872008398.png)
May last layout for my CNC mill:
![](https://cdn.hackaday.io/images/7409741559872059569.png)
The layout shows two slew bearings while the section has three bearings. The prototype bearing was quite good so I don't think I need the second bearing on the tower.
I also have not really considered the tower and the base board.
CNC Mill Parameters
- Restarts: Add origin and maximum extent realignment holes.
- Job Size: One piece at a time.
- Feed Speed: 1200 mm/min (up from 600 mm/min).
- Depth Speed: 150 mm/min.
- Drilling: Peck.
- Over Depth: 0.5 mm (down from 1 mm)
- Spindle RPM: As low at I feel comfortable with, about 3/4 on the dial.
- End Mill: Flat two flute 2mm diameter (better if single flute).
- Cut Depth: 0.25 mm (if all works well this can be increased to 0.5 mm).
- Compensation: 1.8 mm cut width for nominal 2 mm bit diameter (may need to be reduced).
- Use conventional and climb cutting directions where appropriate.
Base Board
The working envelop needs to be 2:1, the key assumptions are:
- Arm 1 length: 200 mm
- Arm 2 length: 150 mm
- Arm 2 rotation limits 10 to 140 degrees
I calculated the following:
Dy | 173.735 | Working Area Height |
Dx | 347.469 | Working Area Width |
L1 | 200.000 | Arm 1 Length |
L2 | 150.000 | Arm 2 Length |
A1Min | -6.143 | Calculated Motor 1 Range (Min) |
A1Max | 115.600 | Calculated Motor 1 Range (Max) |
A2Min | 10.000 | Motor 2 Range (Set Min) |
A2Max | 140.000 | Motor 2 Range (Set Max) |
Ox | -173.735 | Bottom Left Corner |
Oy | 128.598 | Bottom Left Corner |
Here is the base board layout including the tower location:
![](https://cdn.hackaday.io/images/7754391559874767975.png)
It fits on a 400 mm x 400 mm board. This layout has a effectively wider feet spacing.
The normal layout is still 400 mm x 400 mm:
![](https://cdn.hackaday.io/images/2976651559875413482.png)
Tower Design
TBC ...
Limit Switches
TBC ...
AlanX
