Blast your enemies from a safe distance !!!
All parts, wiring diagrams and code available here : littlefrenchkev.com
ASSEMBLY :
WIRING :
FINAL TUNING AND TEST :
View all 19 components
The project is now completed ! I might revisit it in the future with some upgrades but I will leave it as it is for now .
Wiring all done ! Now I just need to make sure the software works properly and I am done !!!
I can start seeing the light at the end of the tunnel !Here is the first part of the final assembly .
I managed to sort out the wiring diagram . I am planning to split the wiring using connectors to make it easy to assemble .
Unfortunately I didn't have much time to work on the project this week but I recorded this short video to show the PC version of the app controlling the turret .
Here is a quick presentation of the android app made to control the turret followed by a mini tutorial on the MIT app inventor .
Today I printed a couple of brackets and test fitted the components .
The final version of both (for MG-90s and MG996R servos) tripods are now printed :
2 versions of the long legs have been printed (2 different types of jack plug) :
Pretty happy as everything fits without having to file or cut anything !
Here I try to explain how I handled communication between devices on this project (phone/PC to arduino) .
I have already done quite a lot on this project but in this first video I go over the 3D model .
View all 10 project logs
Rio King
Cordova Labs
Garrett Brainard
Nick Rehm
Yes, delete it Cancel
You are about to report the project "Bluetooth Nerf turret", please tell us the reason.
