atsamd11c14 Arduino zero compatible ARM M0 compact USB-C stick
I love it! I'm trying to do something similar with a PCB USB connector. How thick is your PCB? Does the USB-C socket fit well? Is it too tight/loose when plugged in?
Schupp
Lexcis
Patel Darshil
land-boards.com
Yes, delete it Cancel
You are about to report the project "DiXi USB-C - arduino sam D11 usb stick", please tell us the reason.
