IV-3, IV-6 VFD 6 digit clock Shield for Arduino
Redesigned AXIRIS IV-3 Shield with DS3231. Battery and buttons ... + 2 Extra Digits
Starting from
$14.24
bobricius has 2094 orders / 92reviews
Ships from Slovakia
Tested only with IV6-tubes
AXIRIS IV-3 Shield for Arduino is super great project, specially power supply is very good designed. etc. filament is driven with AC voltage which is recommended for VFD. 12V input voltage is 3x multipled to make 36V I am redesigned board for easier soldering, all components are in lines with same value
  • added buttons for HOUR / MINUTES
  • speaker driver for make alarm clock, in current firmware is only hour beep implemented
  • components values on PCB
  • DS3231 with battery backup
  • Enhanced to 6 DIGIT
  • hand painted curved traces for more retro look
  • all outputs are marked on pcb for better debugging
  • schematic is almost unchanged, some pins are swapped for better PCB routing
I created simple CLOCK arduino sketch (firmware)
  • IV-3
  • IV-6
  • IV-3 vs IV-6
  • Backlit just parallel connected LED
Little updated new layout.
Large batch PCB ORDER LINK http://dirtypcbs.com/store/designer/browse/bobricius
Required parts list IV‐3/IV-3a/IV-6 shield for Arduino (BOM )
  • 1/4W subminiature carbon THT resistors
PcsvalueDescription
1510 ΩØ1.8x3.2mm
21KØ1.8x3.2mm , tube light, optional
12K7Ø1.8x3.2mm
13K9Ø1.8x3.2mm
1410KØ1.8x3.2mm
1468KØ1.8x3.2mm
14100KØ1.8x3.2mm
14220KØ1.8x3.2mm
  • CERAMIC/MKT /MKM CAPACITORS
PcsvalueDescription
12.2 nF-
1100 nF-
28.2 nF !!!I am replaced with 100nF
  • ELECTROLYTIC CAPACITORS
PcsvalueDescription
422 µF 50V-
2100 µF 25V-
  • DISCRETE SEMICONDUCTORS
PcsvalueDescription
11N400xrectifier diode
41N5819schottky diode
6LED 3mmTube bottom light optional (choose color freely) , optional
14BC547BNPN transistor
14BC557BPNP transistor
1BC639NPN “power” transistor
1BC640PNP “power” transistor
  • INTEGRATED CIRCUITS
PcsvalueDescription
1ICM7555timer IC (must be CMOS version, do not use a standard 555 !)
1DS3231RTC chip , optional
  • CONNECTORS & OTHER PARTS
PcsvalueDescription
1Arduino UNOor clone
28headerspacing 2.54 mm
1CR1220Lithium battery , optional
1CR1220 socketBattery holder , optional
6tubeIV‐3/IV-3a/IV-6 VFD tube
2switchangled, Microswitch TACT
1Piezo 17mmbuzzer, optional
If you want original board go here >
https://www.elektor.com/iv-3-vfd-shield-for-arduino-kit-150064-71
https://www.axiris.eu/en/index.php/project-corner/iv-3-shield-for-arduino
Portable Network Graphics (PNG) - 127.86 kB - 01/05/2021 at 00:16
Preview
Download
Portable Network Graphics (PNG) - 75.72 kB - 01/05/2021 at 00:16
Preview
Download
SimpleCLock6.zip
Arduino code
x-zip-compressed - 5.86 kB - 07/21/2020 at 21:58
Download
View all 3 project logs
Benoit Tourret wrote 07/07/2023 at 14:46 point
Six month than my clock is working 24/7.
The only issue I got was a short circuit with the USB connector housing, I burnt one transistor. replaced easily. I removed the metal shield of the USB plug.
Could a wifi+ntp version could work with the Arduino Uno R4 wifi ?
There is 3 weeks of delay, but I could compile the original sketch without any errors or warning...
tstaff.lx wrote 05/28/2023 at 13:04 point
can someone tell me what voltage the 100nf capacitor are supposed to be.
Benoit Tourret wrote 07/07/2023 at 14:50 point
it is a ceramic capacitor with will never see over 12V.
Jakub wrote 06/02/2021 at 13:29 point
Ahoj jsem tu nový potřeboval bych poradit teprv se učím programovat ještě nic jsem neprogramoval na arduino Uno programuji tyto hodiny jenže mi to hlásí chybu nejde nahrát vůbec mám arduino Uno klon a arduino program nevím jestli se to dá nebo ne párovat díky. Jsem úplný zelenáč.
rezite wrote 04/26/2021 at 18:44 point
Ahoj chtěl bych se zeptat zdali budou tyto hodiny fungovat i s trubicemi IV-11? děkuji
bobricius wrote 05/23/2021 at 19:22 point
musis si skontrolovat pinout a rozmery, potom poprehadzovat nozicky
Ian Sparkes wrote 11/16/2020 at 07:39 point
I can't find the schematic anywhere. I'm trying to figure out what you mean by "filaments driven by AC"? Are you really inverting the filament drive or just pulsing a single ended filament supply?
bobricius wrote 01/05/2021 at 00:16 point
it is look like really inverted voltage. Including schematic in FILES
Alin Marin Elena wrote 11/14/2020 at 21:27 point
so, finally got the time to put all the components together. is the 6 iv-6 board.
Since I do not plan to use the switches I did not install them also nothing from what is marked as optional. unfortunately things do not seem to work all i get are the base leds flashing.
now to debug I would like to understand something
 -  are the 1k and the led need? the ones on top of the buzzer.
- can I get away without the switches?
- shall the underside vin 36 or 12 be connected?
any other suggestion would be appreciated.
Climber20 wrote 07/26/2020 at 06:06 point
You have the Arduino Code with support for ds3231 RTC?
bobricius wrote 09/08/2020 at 11:28 point
yes, DS3231 is supported and code is in files
Jamie wrote 04/26/2020 at 17:51 point
Hi, I am new to electronics and have bought some IV-3 tubes to try to make a clock with. Would using your PCB and listed components be beginner friendly or do you recommend starting somewhere else? Thanks.
bobricius wrote 07/19/2020 at 21:39 point
There is about 130 component to solder and more than 300 solder points, I am not sure if it is for beginner.
Ian Shannon Weber wrote 03/14/2020 at 05:05 point
I hope your project continues to do well.
