LittleArm V3
A Fully 3D Printed Arduino Robot Arm Designed for Hobby and STEM
We want to build STEM kits that get kids excited about technology. So far we have created and launched nearly 10 kits. And now we want to improve our original Arduino Robot Arm again.
We have stayed true to our principles and have made the V3 simpler and more reliable to build and use. So that classrooms can continue to have a great robot arm to implement into their curriculum.
The V3 is live on Kickstarter if you would like to support us.
Whats the "V3"
The V3 is the third version of the LittleArm that we have made. It has fewer parts and relies more on 3D Printing than any of our previous kits have.
The LittleArm Original was the very first kit that we ever created in 2016. Then we followed that in 2017 with the LittleArm 2C. And it took quite a while to find a way to improve on that on. But we found it.
  •  Gripper - We have turned 8 pieces into 1. This gripper eliminates complexity that made it difficult for younger kids to work with the kits. It is also able to grab more stuff.
  •  Overall Design - Sleeker with even fewer screws and complications. Every piece has been optimized.
  •  Improved App and Demos - We have updated the software for the arm and will be releasing new demos.
Overall, we figured out how to further optimize all of the parts to make easier to put together. the gripper that was once 8 pieces is now just 1 piece. Only 2 of the 4 servos need a screw, so kids don't lose those tiny set screws in the rug. And we have made it even tougher so it can take the abuse of classrooms and groups better than ever.
Mechanical Design Upgrades
The LittleArm V3 is the third generation of the LittleArm. And you can tell.
Faster 3D Printing
The LittleArms were the first really viable 3D printed robot arms. But with the V3 we have improved on that. We have reduced the 3D printed part count to just 4 pieces. They can fit on basically any machine and they can be printed at the lowest resolution (0.3mm) in PLA and come out looking great.
Further Optimized Shoulder
The Shoulder from the Original to the 2C was a big leap. But we have gone a step further. Streamlining the should and allowing it to clamp onto the servo. This means we no longer have to use screws for the Servo horns.
LittleArm Shoulder Yokes (L-R Original, 2C, V3) Look at how the design has become sleeker and stronger
New Gripper
When having younger kids build the LittleArms there was always one part that was difficult. The gripper. It had 4 small screws that had to be put in just right and it was often challenging. We wanted to eliminate all of it. But it took a long time and a lot of experiments to create the new V3 gripper.
The V3 Gripper Compared to the 2C Gripper
The new gripper is all one 3D Printed part. The designed spring in one finger eliminates all of the screws but still gives it a full range of motion. All of that complex assembly is eliminated with a really cool design feature that other people can use and learn from.
The New gripper is also able to grab more stuff. The wider fingers let it pick up fabric and also allow us to cut out sections of the claw so that it grab horizontal objects, like a pencil, that were impossible for the original LittleArms
Look at that Awesome New Claw
Only 21 Parts (counting screws)
The LittleArm has the fewest number of parts of any other robot arm kit. to put it together it is basically just snap-and-go the screws just make sure it doesn't fly apart.
Screwless Servo Connection
The LittleArm 2C held the record previously with 31 screws. We basically cut that in half. And any other arduino robot arm you can find will have about 100 pieces in total to be lost as soon as you open the box.
All the Screws Needed for the LittleArm V3
Operates in all Orientations
We have upgraded the servos. They are the strongest metal geared micro-servos in we could find. And they more durable than any others also.
No other desktop robot arm can work in any orientation. Mount it where ever you want. And thanks to our new and improved servos performance doesn't take a hit at all.
Support
To create a kit that is expected to be used in a STEM classroom you have to have great support. We continue to build on what we have done with our previous arms and other kits. And we will continue with great design and a growing library of...
View project log
  • 1
    Video Assembly Tutorial
    To Build the LittleArm V3 simply follow the assembly video below.
View all instructions
Chris Knight wrote 12/28/2021 at 23:44 point
Looks like the SSL certificate for the littlearmrobot.com site has been revoked, are there still folks out there to support this? I'm getting around to toying with my arm and I don't have an Android device so I'd rather drive the arm via serial / Arduino IDE.
