Machinekit can be started with different interfaces. They can be configured with setting DISPLAY variable in INI configuration file
AXIS (unfortunately it crash, when I try to load a cut file):
![](https://cdn.hackaday.io/images/8638291586002829734.png)
tkemc (this one seems to load OK, but refuses to run, since machine need to be homed first):
![](https://cdn.hackaday.io/images/5652841586003011261.png)
There is also a few remote interfaces that need to be tested.
