Protoboard? PCB? Lolly Sticks!
A project log for Calorie Restricted Phone Charging
Stop overcharging your phone battery overnight. This puts your lipo batteries on a strict diet by limiting the mAh passing over a USB cable
bornachbornach 05/09/2020 at 18:320 Comments
I do have spare protoboard, however this build is mostly hooking together other modules and breakout boards with very few through hole components. So I thought I'd save my scarce resources by using crafting lolly sticks to hold everything together..
This is enough to test whether the concept would work before I solder the microcontroller and program it.
