By the end of the previous post, I had decided that the reliability of a direct serial line to the projector wasn’t worth the cost of a MAX232 chip over some IR diodes, so I ordered the latter. I anticipated the process of extracting the IR codes from the remote and replicating them would be difficult, lengthy, and finnicky, but it was actually pretty easy.
220Ω resistor between Photon’s VIN pin and the IR emitter’s cathode
For recording the IR codes from the remote, I used a receiver diode connected to an Arduino Uno with the following configuration:
Receiver Diode
Arduino
+ Cathode
5V out
Signal
Pin 11
− Anode
GND
Then I flashed the IRrecvDump example from Ken Shirriff’s IRremote library to the Arduino Uno, pointed my projector’s old remote at the receiver, and pressed every single button, noting the hex code output to the serial console. It also printed “Decoded NEC” each time, indicating Sanyo chose to use NEC’s IR protocol, which is important to know when sending these codes to the projector later.
I ended up with the following code table:
Remote button
Code
Power
0xCC0000FF
Computer input
0xCC001CE3
Video input
0xCC00A05F
Menu
0xCC0038C7
Left arrow
0xCC007887
Right arrow
0xCC00B847
Up arrow
0xCC0031CE
Down arrow
0xCC00B14E
Select/OK/enter
0xCC00F00F
Digital zoom up
0xCC00807F
Digital zoom down
0xCC0040BF
Page up
0xCC009A65
Page down
0xCC005AA5
Keystone
0xCC00DA25
No show
0xCC00D12E
Auto PC adjust
0xCC00916E
Power-off timer
0xCC0051AE
Image settings
0xCC0030CF
Freeze
0xCC00C23D
Mute
0xCC00D02F
And any time I held a button, it sent 0xFFFFFFFF. I saw an “NEC repeat code” referenced in the IRremote documentation, so I’m assuming that’s what it is. I included it in my final project code, but it is never actually sent, and I have not needed it so far.
When I was done recording the codes, I assembled a second breadboard for “production” use where I had just a Particle Photon,
an IR emitter diode, and a resistor between A5 on the board and the diode to protect the diode. I then strapped this to the
side of my projector so the emitter sat in front of the projector’s IR receiver.
Backend
Speaking of project code, I have uploaded the full code I flashed to the Particle Photon
(with the MQTT server and credentials emptied, of course) as a project file.
It hosts a web interface and API for manual control over the network, but
it also connects to an MQTT server for control by home automation software.
For fun, I designed the web interface it hosts to look exactly like the original remote:
Hopefully, your browser has rendered the HTML document beautifully above.
The HTML document behind this isn’t as pretty as the result,
(especially when represented as a string in the C++ source code) but you can
download it as a formatted HTML file from the project files if you wish.
Clicking a button on that preview will not do anything, but when hosted from the board,
it will make an HTTP POST request to the board that contains the form data key button
and a numeric value. The getCommand function parses this value and maps it to
an IR code for transmitting to the projector.
Sure, a web UI is fun, but it’s not very convenient. Navigating to the page
in a browser isn’t as fast as picking up the remote off the table.
This is where the MQTT functionality comes in.
In Home Assistant, which is connected to the same MQTT broker as the projector
control, I created two scripts: one to turn the projector on by “pressing” the
power button, and the other to turn it off by “pressing” the power button twice
(once to open the “are you sure?” dialog, and again to confirm).
script:
projector_on:
alias: Projector on
icon: mdi:projector
mode: single
sequence:
- service:...
But where to start? I had no idea how to use this port. Luckily, I wasn’t the first to try this. I found “Projector Controllers for Sanyo Projectors”, an old SourceForge project, that attempted to do the same thing. This told me that the service port was an 8-pin mini-DIN serial port. As for my specific model, I found several “serial command manuals” (such as this one for the Sanyo PLC-XU106) that detailed the serial protocol and commands. They were all similar enough (differing only in the number of commands available, which makes sense given the different models have different features) so I assumed the basic on, off, and input switching commands would work with my projector.
Using this knowledge, I found and ordered a breakout connector (shown and linked above) that would let me use such a cable into with my microcontroller boards, and a serial cable to go between it and the projector’s service port.
My projector’s manual did provide a little bit of useful information: the service port pin numbering and assignment (shown below)
Combining this with the datasheet for the breakout connector from Mouser, I created this mapping table:
Projector
Number
Color
Arduino
RXD
1
Brown
TX (3)
2
White
3
Black
GND
4
Blue
RTS/CTS
5
Green
TXD
6
Yellow
RX (2)
GND
7
Orange
GND
8
Red
GND
Despite the presence of an RTS/CTS line, the manual says that flow control is not needed.
Now I had everything I needed to communicate with the projector using an Arduino Uno I had laying around. I wrote the following sketch to be able to write my own data out and receive incoming data while sending the required CR between commands:
#include<SoftwareSerial.h>SoftwareSerial projector(2, 3);
char buffer[64];
byte index = 0;
voidsetup(){
Serial.begin(19200);
while (!Serial);
projector.begin(19200);
while (!projector);
Serial.write("Ready\n");
voidloop(){
// Projector -> PCif (projector.available()) {
Serial.write("RX: ");
while (projector.available()) {
Serial.write(projector.read());
Serial.write('\n');
// PC -> Projectorwhile (Serial.available()) {
char c = Serial.read();
if (c == '\r' || c == '\n') {
// Send buffer to projector
projector.write(buffer, index);
projector.write(0x0D);
// Echo buffer
Serial.write("TX: ");
Serial.write(buffer, index);
Serial.write('\n');
// Reset buffer
index = 0;
} else {
// Add to buffer
buffer[index++] = c;
But did it work? No. I sent many commands through the serial console and got left on read an equal number of times.
To figure out what was going on, I hooked up a logic analyzer to all of the lines and recorded sending messages from the Arduino and waiting for a response, as shown here:I’m not sure what the ‘255’ on the GND line was from, but I’m assuming it was just crosstalk due to the cheap breadboard I was using.
After another couple hours of trying different combinations of wires and serial data, I figured it must be the incorrect voltage. The Arduino was only communicating with 5 volts, but RS-232 could go much higher. If the projector was expecting 12 volts, it wouldn’t count 5 volts as a signal. Before sending higher voltages into my projector without knowing, I decided to email the person behind the Projector Controller project on SourceForge that I mentioned earlier. I figured it was a long shot that the email was still valid because it had been 10 years since the project was last active, but I was desperate.
I sent an email asking about what voltages were tested and working, and to my surprise, I got a response, and quickly! The relevant part:
Its been a while since I looked at this. In my circuit I used a max232 level converter chip, so I’m guessing its 12v. It should be reasonably safe to try this. In my other software project I would have used a usb to serial converter which also would likely be 12v.
Looks like I was right. Unfortunately, the level converter chips aren’t cheap, and I had already spent about $15 on this project, so I assumed I was...
The backstory: Many years ago, I bought an old Sanyo PLC-XU48 from Craigslist for $50. Since then, I’ve used it as a TV to watch videos and movies and play games. The resolution (1024x768) isn’t great by today’s standards, but at a distance it’s fine for my use.
The problem: Recently, the power button on the remote has decided to only work a tiny fraction of the time, which is really frustrating when trying to double-press it to turn off the projector.
First attempt at a solution: A new remote? Boring. Serial is much more exciting! I have some Particle Photon boards, which are Arduino-like microcontrollers with WiFi and I wanted to use one to communicate with the projector through its serial “SERVICE” port instead of using the remote. This would also let me integrate it with Home Assistant or write a web interface.
