Smoothiewear for Pick-and-Place Machines
01/22/2021 at 13:01 • 0 commentsOne of the main developers for OpenPnP created a version of the Smoothieware firmware to account for some of the issues that arose in Smoothieware when using it for pick-and-place machines. You must download it from his website. Be sure to select the version that is appropriate for you (5-axis or 6-axis).
https://makr.zone/smoothieware-new-firmware-for-pnp/500/
Be aware that this version of the firmware uses a slightly different version of the configuration file. My configuration files are on a Github site. You can find the link on the main page of the project.
Limit Switch Sensors
01/18/2021 at 14:53 • 0 commentsSensors
I tested 4 different limit switches to see how they would perform with a Smoothieboard. The results varied.
1 – Red cheap optical sensor (less than $1)
2 – Black cheap optical sensor (less than $1)
3 – Omron EE-SX672A optical sensor (~30$)
4 – Mechanical switch (less than $0.50)
Smoothieboard Setup
Numbers 1, 2, and 3 read high when not activated and low when activated. Because of this, you need to use the “!” to invert the pin logic in the Smoothieboard configuration file. By default, Smoothieware expects low to be not activated and high to be activated.
For the mechanical sensor (4), it was connected between the signal pin and the ground pin. The normally closed terminal of the switch was used. That way when not activated, the pin was pulled low (as Smoothieware expects). When the switch is activated, the connection is open and the signal pin goes to high (as it is set to pull up).
Results
The optical sensors (1, 2, and 3) were first tested using a benchtop power supply and found they would work if set up correctly.
When using the Smoothieboard, number 1 worked, but just barely. It read about 1.2 volts when activated which was just below the threshold Smoothieboard needed to detect a low signal.
Number 2 did not work. It reads about 2 volts when activated and this was not low enough for the Smoothieboard to recognize it was activated.
Number 3 worked perfectly. This sensor came with the pre-assembled pickup head I bought. It is used as the Z-axis homing sensor.
In the configuration file, you can tell Smoothieboard to pull the sensing pin low, high, or leave it floating. Sensors 1 and 2 seem to want the pin floating. However, regardless if I set the pin to pull low, pull high, or float in the configuration file, the value at the pin was still high. (I’m not sure if this is a general Smoothieboard issue or an issue with my particular one.) This may be been the reason numbers 1 and 2 did not perform well. Sensor 3 wants the pin pulled high. This may be the reason it worked.
The mechanical switch, Number 4, worked perfectly. Because it was both cheap and reliable, this was the sensor I used for the end stops on the X and Y-axis.
Discussion
Mechanical Advantages
The mechanical switch had some additional advantages. The optical sensors require an additional component to act as a beam interrupter to trigger the sensor. These beam interrupters also require additional mounting hardware and they require three wires to connect instead of two. While these are minor things, fewer parts and wires are always preferred.
Accuracy of Mechanical versus Optical
The Smoothieboard page advises the use of mechanical sensors because they are more accurate in terms of repeatability. There are those who disagree. For pick-and-place machines, this is an academic discussion and isn't practically relevant.
For the X and Y-axis, OpenPnP uses the limits switches to home to a known position on the machine and then uses the more accurate optical homing. Thus, close is good enough for the limit switches.
For the Z-axis, both Juki and Samsung type nozzles have built-in travel which allows for small amounts of forgiveness to positioning errors.
Conclusions
In terms of accuracy, I think your time is far better spent worrying about other sources. Good optical sensors or even some low-cost ones should work. Mechanical switches are tried and true and perform well. In the end, you have to select what works for you.
For me, the simplicity and reliability of the mechanical switches led me to select them for my X and Y-axis limit switches. I purchased a pre-assembled head that had a functioning optical switch already attached (switch 3). I used that as my Z-axis sensor.
Smoothieboard Issues
01/11/2021 at 13:15 • 0 commentsIntroduction
Please be careful if you decide to buy a Smoothieboard for your project. There are a lot of clones out there and some of them are poorly manufactured. A lesson I learned the hard way.
When I got my Smoothieboard, one of the first thing I noticed was the fit and finish was rather poor. The female end of the main power connector (for Vbb) did not fit into the male end. The end stop connection points were so close together the connectors did not all fit. One of the connection points was populated with header pins instead of a connector. The list goes on.
Hopefully, the information here will help you select a better one or resolve issues if you have a poorly manufactured clone.
Wrong Potentiometers
Some of the Smoothieboard clones have alternate potentiometers that give the stepper motor drivers bad reference voltages and the motors won't operate correctly. The bottom image should help you identify if this is your case. A link to a page describing the issue and solution is below, but the short answer is to add the following to your configuration file:
# Fix for incorrect Digipots used on Smoothieboard Clones.
digipot_factor 36.6Page describing the issue:
https://forum.makerforums.info/t/aliexpress-fysetc-smoothieboard-v1-1-mcp4441-issue/77926Selecting a Smoothieboard
Unfortunately (in the U.S. anyway), it is hard to find officially sanctioned boards. The Smoothie website has a list of vendors, but the list is short and the U.S. vendor is out of stock (or no longer carries them).
Price is something of a hint. A sanctioned Smoothieboard is just shy of 200 dollars U.S. However, that's not a guarantee, one way or the other, that the board is good. I'm sure there are high priced garbage boards and quality boards for about 100 dollars.
The images below provide some things to look for, but nothing is guaranteed. Research whatever board you are looking at, try to find reviews, and use your own judgment.
Mechanical Design Update
12/30/2020 at 17:18 • 0 commentsTwo options for the x-axis were explored. The first option was with the 2040 aluminum extrusion upright (40 mm dimension vertical). The second option was to lay the extrusion on its side (40 mm dimension horizontal). In theory, either should work. Practical matters usually are the difference-maker.
In this case, the cable chains and the connections between the x-axis and y-axis starting driving the design. Placing the x-axis extrusion horizontal simplified things. The corner brackets used in the x-axis to y-axis connection were no longer required. The x-axis cable chain could ride on top of the back of the x-axis extrusion, eliminating the need for extra support brackets. And the same bracket used to mount the x-axis motor could also work to mount both x and y-axis cable chains.
