As previously seen,
https://hackaday.io/project/176214/log/212713-propdrive-dreams
the cheapest way to get more speed was seen as creating a modular nose cone rather than expanding the motors, using hotter windings, or expanding the battery. The nose cone had to be field removable without tools, stowable so the leash could be accessed, & not cover the headlights.
The 1st step was converting the headlights to a narrow strip.
Various nose concepts followed, with cardboard, coroplastic, & PLA. After many miles, the best performing one was 3 sided with permanent string holding the bottom & a removable string farstening the top to the truck.
Ideal speeds with a nose cone:
# dist sec min/mile 1 213 43 5:42 2 201 44 5:45 3 203 44 5:44 4 208 46 5:49 5 201 46 6:3 6 211 44 5:51 7 205 46 5:52 8 208 44 5:53 9 206 47 6:0 10 204 45 5:43 11 211 43 5:42 12 200 44 5:47 13 203 46 5:58 14 306 70 6:6
Typical speeds without a nose cone:
# dist sec min/mile 1 208 48 6:9 2 305 73 6:24 3 405 98 6:28 4 408 103 6:43 5 404 100 6:35 6 404 100 6:34 8 400 101 6:45 9 407 110 7:14
Speeds with a nose cone were highly variable, depending on weather, payload, wheel alignment. Without a nose cone, it was guaranteed to have a hard time getting above 6:30/mile. With a nose cone, there was a possibility of it getting above 6:00/mile.
There's no correlation with the number of sides of the nose cone. A 2nd nose cone on the back might buy it more speed.
The latest nose cone is glossy & collapsible. It rests on the bumpers while clearing the leash.
