But How Do It Know? 8-bit CPU Build
Hybrid implementation, using SN74HC chips and Arduino Nanos, of the 8-bit CPU described in J. Clark Scott's book "But How Do It Know?".
Hybrid implementation, using SN74HC chips and Arduinos, of the computer described in J. Clark Scott's book "But How Do It Know?".
In this project I am creating an implementation of the computer described in the book "But How Do It Know?" by John Clark Scott.
The book explains how a computer can be built using only NAND gates. I am not doing a "purist" build as that would be too large and expensive, but instead am using Arduino Nano microcontrollers and SN74HC chips to simulate some of the different parts. I am also making a video series that shows how the different parts of John's design work before implementing them on the Arduinos or SN74HC chips.
In the end I hope to have a portable-sized 8-bit computer simulator that anyone can not only build, but also program and extend if they desire.
The video series is here: Companion Video Series to "But How Do It Know?" - YouTube
Code and more info can be found here: https://github.com/patrickleboutillier/jcscpu-hmc/
  • 1 × But How Do IT Know? Book http://buthowdoitknow.com
  • 1 × 14"x10" Wooden Cutting Board
  • 8 × Breadboard Electronic Components / Misc. Electronic Components
  • 4 × Arduino Nano
  • 7 × SN74HC373 D-type Latch
View all 24 components
View all 19 project logs
View all instructions
JC wrote 01/04/2021 at 03:37 point
With all given respect , that is total non-sense...using four 8-bit MCUs to emulate PART of one 8-bit CPU....if you really want to do something that increase your own knowledge and the one of your audience you could implement such 8 bit CPU using a FPGA and program it using VHDL....that would be a very valid transferable experience and knowledge...something like that does not make any sense neither technically, nor economically, nor from time efficiency, portability, reusability, space usage, reliability....absolute non-sense!
