Just gotta flag up this project: #Hacking any linear slide/bearing into piezo motor posted by @Edwin Hwu.
"Herein we present the design of an open-source XYZ-axis nanopositioning system. Utilizing a magnet-based stick–slip driving mechanism, the proposed XYZ nanopositioner provides several advantages, including sub-nanometer resolution, a payload capacity of up to 12 kg (horizontal), compact size, low cost, and easy assembly; furthermore, the system is adjustment-free. "
![](https://ars.els-cdn.com/content/image/1-s2.0-S2468067222000621-ga1_lrg.jpg)
The project links to a journal article. The journal looks a bit like HaD with editorial standards and peer review. And it's open access. The existence of open access journals is something of a successful hack itself, but I am at risk of digressing further...
Actually not only linear slide, any rotational motion ball bearing can be driven by the same mechanism ;)
Even better! I missed that.
