Just a quick update - I've ordered some USB C breakout boards which will enable me to use a meanwell power supply mounted under the pedalboard to power both Raspberry Pi boards with a normal usb c cable.
EDIT
They have arrived.
Tomorrow I will try to solder them all together and look for a safe way of mounting them.
![](https://cdn.hackaday.io/images/4409681629223156861.jpg)
