It is so sad that the station falling down, I did not even know how it falls down. it is fortunate that the anemometer and wind transducer are not damaged and still working well.
What happens since I put the station to the roof?
I checked the update in the Thinkspeak every two hours since that, and the data is working well. I thought the station would be continued to work that I paid less attention to it.
Until the seven days passed, I found the data in the Thinkspeak did not change anymore which reminded me something happened for it.
I had checked it once again, and the reason fell dwon was that the station support was unstable. The solar panel holder has been broken, and others are lucky.
![](https://cdn.hackaday.io/images/237521626762004531.jpg)
I had to remake the solar panel holder again and add some metarials to fix the supports stability.
![](https://cdn.hackaday.io/images/2300991626762045876.jpg)
All is why the data did not update in the thingspeak in the past few weeks.
