The photos below show the evoluton of this module.
On the right there's the original DM9368 based module and the two on the left use the PIC.
It's a much cleaner design with the PIC and much smaller too.
The 3D design helps...
A project log for Dual 7 Segment Hex Display Module
Two digit (8 bit) hex display using a PIC16F18446 microcontroller
