After a short break to work on other things, I am back working on this project. I've expanded the capability goals and am adding a small CNC mill that integrates with the Pi controller so it will be able to quickly drill PCB holes. This "QwickDrill" module will be optional, but should add a lot. Here is a sneak peek at the Fusion 360 design:
