MPU-232 : RS-232 MIDI interface
MIDI interface for the serial port, compatible with softmpu
MPU-232 is an RS232 to MIDI interface, compatible with SOFTMPU :
- fits on 9 pin serial port
- MIDI output DIN connector
- 5V supply through USB mini connector
- DIP switches for advanced settings
- Compatible with softMPU for DOS gaming
Available here : https://www.serdashop.com/MPU-232
MPU-232 is an RS-232 serial port to MIDI converter.
Usage with SoftMPU :
SoftMPU uses 38400 baud, binary mode.
--> Set all dips to OFF to use with SoftMPU. (this is the default state of the dips).
Set the output device of softmpu to your com port : for example :
SOFTMPU.EXE /MPU:330 /OUTPUT:COM1
DIP switch positions :
DIP 3 : OFF = binary mode, ON = ASCII mode
DIP 1 + 2 : baud rate selection (38400, 19200,9600,4800)
Using with sam and max, softMPU driver :
Using with realms of chaos, softMPU driver :
JPEG Image - 59.02 kB - 05/24/2021 at 15:51
Preview
Download
View project log
