![](https://cdn.hackaday.io/images/4523601631550148752.jpg)
A Connector board is used to connect the S-drive BLDC driver to the 24 power supply and to the teensy microcontroller. They are designed to be stacked one on one with brass spacers.
![](https://cdn.hackaday.io/images/1408731631550362961.jpg)
A project log for CM6 - Compliant 3D printed robotic arm
Cheap, Open-source, safe, and compliant 6 - Axis 3d printed robotic arm based on Quasi direct drive BLDC drives.
