This is a 3D printed actuator designed for robotic Joint usages
Base Motor - ex8108 Controller used - moteus Reduction ratio - 6:1 approxAll M4 bolts to mount use 6mm smooth rod for shaft
Standard Tesselated Geometry - 596.08 kB - 08/14/2021 at 21:21
Standard Tesselated Geometry - 416.00 kB - 08/14/2021 at 21:21
Standard Tesselated Geometry - 147.93 kB - 08/14/2021 at 21:21
Standard Tesselated Geometry - 304.48 kB - 08/14/2021 at 21:21
Standard Tesselated Geometry - 117.56 kB - 08/14/2021 at 21:21
View all 9 files
Solenoid
Dongil Choi
Miguel Ángel Casanova
Tom Baden
Yes, delete it Cancel
You are about to report the project "Agile Actuator :)", please tell us the reason.
