Drawing 1a DVD Diffraction Grating Frame assembly
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 11/30/2016 at 19:420 Comments
This is the frame assembly from the previous drawings that illustrate the diffraction grating placement on top of the Schott glass filter at the detector. The DVD piece is cut @ 20 x 20mm and placed within the 1mm inlay of the frame with a dab of glue (DO NOT use crazy glue!)
