Replaced DVD Diffraction Grating for The DAV5 V3 (a) Raman Spectrometer
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 12/13/2016 at 15:320 Comments
Replaced the 4.7G DVD piece I was using for the diffraction grating, and replaced it with an 8.5G one. Now I have a ruling density of 0.36mm, which now gives me a wavelength range of 360nm (0.36mm *1000 = 360nm) and 2770 lines per mm, for a spectral resolution of 0.18nm, using my 150mW laser's FWHM as my measurement:
