Fixed 32mm Focusing Lens Assembly for The DAV5 V3 Raman Spectrometer
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 12/19/2016 at 13:270 Comments
I had to add a 5mm wide spacer behind the 32mm lens, I found through some experimentation that the increased 5mm distance sharpened the image significantly by a factor of 4, so the old focal distance was 65.2mm from lens apex to mirror's center, now it is 70.2mm from lens apex to mirror's center.
