How Do You Calculate The FWHM of the Instrument Profile?
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 12/26/2016 at 22:550 Comments
Below is a comparison between a laser scan today (12/26/2016,) and one done on 9/28/2016
DAV5 V3 spectrometer; DVD diffraction grating-2770 gr/mm { 1 x 0.19 x 2770 = 5263}{531.94/5263 =0.10}
Resolution profile (present) = 0.10nm With a slit width of; 120um
What laser wavelengths are used for Raman spectroscopy?
Laser wavelengths ranging from ultra-violet through visible to near infra-red can be used for Raman spectroscopy. Typical examples include (but are not limited to):
The choice of laser wavelength has an important impact on experimental capabilities:
http://www.horiba.com/scientific/products/raman-spectroscopy/raman-academy/raman-faqs/what-laser-wavelengths-are-used-for-raman-spectroscopy/
